05-15-2014, 08:57 PM | #1 |
signal indicator
I need some help on my 71 chevy pickup. When I turn my headlights on my left signal indicator lights up. I have replaced the grounds all over I changed the light switch out because it was sticking but havent found the issue yet. Can anyone help me?
05-15-2014, 09:01 PM | #2 |
Re: signal indicator
You don't have light bleeding through the areas around the turn signal indicator lighting it up do you? Sometimes those clusters aren't sealed between the spaces very good That may be too simple to be the trouble. Jim
05-15-2014, 09:14 PM | #3 |
Could be a turn signal at one of the corners that isn't making a good ground connection. try unplugging them one at a time and see if that narrows it down.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
05-15-2014, 09:23 PM | #4 |
I dont think I have light bleed over but I will check that and the signal lights. Thanks
05-16-2014, 09:39 AM | #5 |
You have a bad bulb somewhere. Check your front and rear turn signal bulbs. Whenever a bulb is bad, it causes a dash blinker to remain on.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
