05-23-2014, 01:35 PM | #1 |
can I use my 3/4 calipers and spindles with a 1/2 ton rotor?
I have a 1985 GMC Sierra Classic 2500 with the towing package brakes and 8 lug bolt pattern. I'm not sure of what size rotors and calipers an all that I have but my question is there a way to use what I have existing and go to a 5 lug bolt pattern?
I ask because I like my braking but I want the 5 lug bolt pattern for greater wheel selection. Also, I don't know what rear-end I have but it's huge and it has 14 bolts. My end goal is to install a Porterbuilt front DropMember and KP Components 4-link cantilever rear. |
05-23-2014, 01:42 PM | #2 | |
Re: can I use my 3/4 calipers and spindles with a 1/2 ton rotor?
Different animal. Here are the brake system release charts (for '74 and for '87) in case you want more detail. http://67-72chevytrucks.com/vboard/s...d.php?t=510519 K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-23-2014, 02:01 PM | #3 |
67-72 parts collector,…
Actually there is a way.
Www.earlyclassic.com sells a c20 to c10 spindle. (C30 has the same ball joint and tie rods as the c20) These conversion spindles allow you to use your existing a-arms and tie rods. Install them with HD1.25" wide 1/2-ton rotors calipers and bearings. It's a super easy way to get 5-lug wheels on the c20 and c30 trucks.
05-23-2014, 03:02 PM | #4 | |
You would lose some braking, though, by going to a smaller 1/2 ton rotor and caliper. K
05-23-2014, 03:22 PM | #5 |
Slots go on anything!
My '74 had D52 calipers on the front, FWIW. I was doing a 1/2 ton suspension swap anyhow, so I just used them, since they had fresh pads and hoses.
1974 Jimmy- 5.3/4L80e/NP241 |
05-23-2014, 04:04 PM | #6 |
Thing is I will be going with a Porterbuilt front Dropmember system which will come with new upper/lower control arms and lowered spindles. I can get this setup for a C20, but I want to run the 5-lug setup for wheel options.
at EarlyClassics, I see the C20 3/4 ton to 1/2 ton spindles. I might get the Porterbuilt kit without spindles and use these spindles.
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24. /Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat / SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed |
05-23-2014, 04:27 PM | #7 |
As long as the frame dimensions are correct for your C20, I would go ahead and run the C10 parts on the front. I am guessing towing is not your goal.
