Old 07-15-2014, 02:42 PM   #1
davepl
davepl's Avatar
Washer pump
Ever have one of those moments when you wake up in the middle of night, sit straight up, and realize you've solved a problem that's been stymieing you? I had that last night, but I don't know if I'm right yet. I even emailed myself so I wouldn't forget.
Anyhow, as I near completion of my complete reassembly I've discovered my washer pump doesn't work. I siphoned water right up to it so it doesn't have to work to prime itself, but no luck.
I'm wondering now if the washer nozzles got plugged with media when I had them in the vibratory tumbler. That's my hope and my "big idea". Easy enough to check.
Before I do, though, a question: I can -hear- the pump operating. It does it's little thing. I've heard that if the 'cam' isn't aligned with the motor the pump won't work, but would I still hear it?
That's the question - I'm trying to rule out the pump cam as an issue based on the fact that I can hear something going on in there...
I really don't want to replace it. I have AC so it's a nightmare of packaging with the crazy air tubes, vents, radio, speaker, washer pump, instruments and everything packed in right there.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-15-2014, 03:56 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: Washer pump
Sounds to me like you may need that little 9.00 washer pump gasket repair kit that is easy to install with the radio out of the truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-15-2014, 04:40 PM   #3
davepl
davepl's Avatar
Re: Washer pump
Can you get to it with the radio out on an AC truck? That particular AC hose you don't want to remove as it runs all the way to the driver's side vent.
Old 07-15-2014, 04:54 PM   #4
truckster
truckster's Avatar
Re: Washer pump
Unless you're trying to keep your truck bone-stock, one of the cheapest and most effective upgrades is an S-10 washer bottle with the integral pump. They work great and have a lot more pressure than the original pumps in our trucks. You can wire them into the original switch, too.
truckster is offline   Reply With Quote
Old 07-15-2014, 05:21 PM   #5
kcsa75
kcsa75's Avatar
Re: Washer pump
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 07-15-2014, 07:29 PM   #6
pwdcougar
pwdcougar's Avatar
Re: Washer pump
Great idea.
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those"
1969 Mercury Cougar Standard 4 speed
1969 Mercury Cougar XR7 convertible
1970 4WD Chevrolet Suburban
1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997)
pwdcougar is offline   Reply With Quote
Old 07-15-2014, 08:02 PM   #7
davepl
davepl's Avatar
Re: Washer pump
I've been intrigued by the S-10 part but do want to keep as close to 100% stock appearing as possible. Not that I've not made any concessions, but the windshield washer pump isn't like 3-point belts or disc brakes where I have a safety incentive (outside muddy roads, I guess).
Could it all be stuffed into a 1960s washer bottle and wired discretely, or would they be far too different in size, etc?
Old 07-15-2014, 08:48 PM   #8
bigmac73
bigmac73's Avatar
Re: Washer pump
i just hooked up the universal pump from NAPA works great it is the size of a D Battery and cost around 25 bucks, toggle switch under the dash , a lot easier than trying to mess with the factory one
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-15-2014, 10:57 PM   #9
Already Gone
Re: Washer pump
I do not know but its right there with the radio removed in a non A/C truck.
Old 07-16-2014, 12:33 AM   #10
truckster
truckster's Avatar
Re: Washer pump
I have my entire front clip off right now and I can't find my pics that have the washer bottle from the S-10, but it really doesn't look out of place under the hood. I even used some stock mounting holes on the left fender.
Old 07-16-2014, 06:45 AM   #11
twouvakind
twouvakind's Avatar
Re: Washer pump
I know you have some history with anti freeze bottles, you didn't use the windshield washer fluid jug in a pinch..didja? Just kidding.
twouvakind is offline   Reply With Quote
