Old 07-15-2014, 05:13 PM   #1
Bernman72
1956 Chevy Truck rear end setup question
I have a ford 9" rear end I putting in the 1956 chevy truck with 4Link suspention from full tilt. Can someone help me with the degree the rearend should be setting at if any? I have to cut the old lief spring pads off and weld in the new ones for the bars.
I just put in the mustang II in the front with no drop spindles and coil overs all the way around.
Thanks for your help.
Bernman72 is offline   Reply With Quote
Old 07-15-2014, 05:22 PM   #2
Bernman72
Re: 1956 Chevy Truck rear end setup question
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
Old 07-15-2014, 06:10 PM   #3
topdown99
topdown99's Avatar
its been a long time, but I thought the pinion should be up 2-3 degrees from flat ... I am certain someone with more current knowledge will be along to give input soon.
1957 3100 - 235/4spd - CPP 3" front drop axle & disc brake kit, CPP rear suspension kit, 15x7 & 15x8 Corvette rally wheels
topdown99 is offline   Reply With Quote
Old 07-15-2014, 06:24 PM   #4
Wrenchbender Ret
The pinion angle needs to be parallel with the engine. from 1 to 3 degrees. I can't seem to illustrate it.
_______
________
Wrenchbender Ret is offline   Reply With Quote
Old 07-16-2014, 11:18 AM   #5
Bernman72
Thanks for the help, I will put it @ 2 and use the adjustment on the arms to tune it in later.
