Old 07-17-2014, 09:50 PM   #1
jeffahart
jeffahart's Avatar
Is steering damper bushing sleeve needed Dana 60
I just put a dana 60 in my K20. There was no steering damper or hardware. I ordered a Skyjacker stabilizer and it came with bushing but no metal sleeve.
Is it supposed to be installed with a sleeve?
Thanks,
jeff
jeffahart is offline   Reply With Quote
Old 07-18-2014, 05:30 PM   #2
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Is steering damper bushing sleeve needed Dana 60
Some have a tight fit of the bushing onto a bolt intended for mounting shocks. That's how my skyjacker stabilizers are.
If the mounting bolt are the same type as the above picture no sleeve is needed.
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 07-19-2014, 02:15 AM   #3
kwmech
Thanks,
jeff
You should have gotten the bolt which will fit tight in the bushing, a 1'' spacer, which goes in between the shock and the mount and a stud for the tie rod end of the shock with a castle nut. Pics?
kwmech is online now   Reply With Quote
Old 07-20-2014, 10:16 PM   #4
jeffahart
jeffahart's Avatar
They sell skyjacker 9000 stabilizer with or without the hardware. I managed to order without the bolts. Now I need to try and buy bolts alone tomorrow. The kicker is they are the same price with or without the hardware.
