Old 07-31-2014, 11:06 AM   #1
abohler1
abohler1's Avatar
Bagged Bodied and Track Ready? Best of both worlds.
I posted this in the 67-72 forum as well, someone suggested I ask/read over here.
-I have a 70 C10 that is bagged and I am a real performance guy. I am building an LS swap and should make about 650hp on motor. I am really torn and wanted to ask some suggestions. I love the look of bodied trucks, but I also want to get the power to the ground and track. I would like in the long run to run nitrous on the motor and get street slicks to put down good runs.
-Is there a good way to have the best of both worlds? Can I body the truck and keep it bagged, but spruce up the frame and other suspension components to run at the dragstrip? I would like to have a ten second truck, and also body it with different wheels for weekend shows.
Any thoughts? Thanks All.
abohler1 is offline   Reply With Quote
Old 07-31-2014, 11:39 AM   #2
tinydb84
tinydb84's Avatar
Re: Bagged Bodied and Track Ready? Best of both worlds.
Look up Smitty's truck with the No Limit Wide Ride set up
David
Instagram: myfabguy
Old 07-31-2014, 12:32 PM   #3
CHRIS67GMC
CHRIS67GMC's Avatar
Yes you can. I have ran 11.16 on Shockwaves. We have a rail in the 6s also. I have multiple ways to do your whole set-up.
Call me
419-448-8080 or 419-934-5257
Smitty
CHRIS67GMC is offline   Reply With Quote
Old 07-31-2014, 01:42 PM   #4
abohler1
abohler1's Avatar
Call me
Smitty
I am really excited to hear you hopped on this so quickly. I am really just gauging my project options at this point. I have most of my money going into the drive train right now, but will be ready once the engine and trans are in the truck.
Is a lot of the work going to be getting a new chassis, or can I work on the original chassis and add rigidity? Run a front cross member, rear trailing arms, etc? Thanks so much for the help.
Old 07-31-2014, 02:02 PM   #5
CHRIS67GMC
CHRIS67GMC's Avatar
Look at my build thread.
Old 07-31-2014, 07:29 PM   #6
tinydb84
tinydb84's Avatar
Take a look at Rob from No Limit JT build thread.
David
Instagram: myfabguy
Old 08-01-2014, 12:00 PM   #7
abohler1
abohler1's Avatar
Your build thread is awesome! I am about half way through it. I am getting a ton of great ideas. Thanks so much.
Old 08-01-2014, 12:00 PM   #8
abohler1
abohler1's Avatar
Thanks for the heads up. I'll go check that out. Much appreciated guys.
Old 08-02-2014, 03:44 PM   #9
502ms
502ms's Avatar
Yes. It can definitely be done. Glad you found these guys.
My goals are a bit more HP, and I'm already bagged to lay frame. Want to run auto cross occasionally and hit the drag strip to let you know what my 1000hp means in seconds.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 08-04-2014, 10:39 AM   #10
abohler1
abohler1's Avatar
Your build was pretty awesome. Glad to see high hp trucks bagged, but still able to put the power down. I am already bagged, but low and slow. Once my LS swap is done, I will get a chance to see what needs to be done to get the suspension tuned for the track. Good to see I am not in this endeavor alone.
