07-31-2014, 05:24 PM | #1 |
Please help me find brake line fitting
Hey guys! I am trying to find a fitting that threads into my GM 12 bolt rear wheel cylinder. I have thru frame bulkheads that have AN sides for the flex hose that goes to the wheel cylinder.
What I am looking for is an adapter that will thread into the wheel cylinder but takes a 3AN flex hose fitting on the other side. I am not sure what size thread the wheel cylinder is. Here is a pic of the old fitting with the standard hard line. what size thread pitch do I have? Does a fitting even exist to do this? THANX!!! |
07-31-2014, 06:49 PM | #2 |
Never Ending Projects
Re: Please help me find brake line fitting
Not sure exactly what you are doing. Do you have drum brakes on the rear or disk brakes? If drum, you should not have any flex lines on the axle, only the flex line from the axle to the frame.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
07-31-2014, 07:15 PM | #3 |
I'm sure any NAPA and most parts stores will have that fitting, or you can buy preflared lengths of tubing from any parts store.
Unless you have a tool to make double flared ends, you may just want to bend up a length of premade tube. |
07-31-2014, 07:48 PM | #4 |
Currently I am planning on running drum brakes. But the plan was to not run the conventional hard line across the rear from drum to drum. I was hoping for a cleaner look. So instead I put thru frame bulkheads into the frame with the anticipation of running disc brakes at some point down the road. In the mean time I was hoping to find a fitting that would go into the wheel cylinder that would allow me to put a 3AN flex line on. I've seen it done this way with discs....Not sure why I couldn't do it with drums.
07-31-2014, 08:03 PM | #5 |
07-31-2014, 08:03 PM | #6 |
3/8-24 male inverted flair. This is the size on my 72 12 bolt.
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother |
08-01-2014, 02:03 AM | #7 |
Ah, now I see what you are doing. I think this is what you need.
http://www.summitracing.com/parts/ear-581531erl or this, if you need a longer thread http://www.summitracing.com/parts/ear-581533erl
08-02-2014, 02:14 PM | #8 |
