Old 08-22-2014, 02:05 PM   #1
brawley
Easy Does It
brawley's Avatar
Rear end width change??
I thought I remember hearing that in 1970 they widened the rear end 1 1/2" wider than the 67-69 models, anyone know if this is true?? thanks
brawley is offline   Reply With Quote
Old 08-22-2014, 02:11 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Rear end width change??
Yes it is, 3/4" on each side. I think it was '71 though....
Someone will correct me if I'm wrong on the year.
LockDoc
Leon
Old 08-22-2014, 02:16 PM   #3
michael bustamante
michael bustamante's Avatar
70 model c10 came wiith both 67-69 and 71-72 length rear ends but they are ALL 6 lug still. I have a long length 70 rear end 6 lug under my trailer
1967custom
michael bustamante is offline   Reply With Quote
Old 08-22-2014, 02:20 PM   #4
Coley
Coley's Avatar
Smile Re: Rear end width change??
Full agreement with LockDoc's comments....it was widened in '71.
I believe the reason for this was that they introduced disc brakes onto the trucks in '71 and this disc brake assembly was wider than the previous front drum brakes.
Again, to my understanding....they then made sure the rear track had the same width as the front.
Like Lockdoc also said,....someone correct me if I'm wrong on this.
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 08-22-2014, 02:26 PM   #5
NC67Chev
NC67Chev's Avatar
Agree with Michael. I just put a wide 6 lug rear end from a '70 on my '67. I actually think some late '69's got the wide ones too.
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 08-22-2014, 06:23 PM   #6
70shortstep
Registerd User
70shortstep's Avatar
My 70 has the wide rear end.
John
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=613398
70shortstep is offline   Reply With Quote
Old 08-22-2014, 06:42 PM   #7
Wizo
Wizo's Avatar
i had heard this also. Then it dawned on me that i had had a 71 rear end overhauled for my 68 short step side.Now i think my wheels and tires are going to stick out. Anybody ever shortened the axel tube and then put in shorter inner axels? Is it possible to buy shorter inner axels? I could just put the 68 axel back in but i spent good $$$$$$ to have this one overhauled and turned into a 3.73 posi. many thanks in advance.
Wizo is offline   Reply With Quote
Old 08-22-2014, 07:12 PM   #8
NC67Chev
NC67Chev's Avatar
Does your '68 still have drum brakes? If so, I think your front and rear will be about the same width after the '71 rear is added. If you've upgraded to disc brakes, I think the front will still be wider than the rear...even with wider rear end.
Old 08-22-2014, 09:12 PM   #9
too much stuff
Roadtrip!
too much stuff's Avatar
I believe 70 was the change over. Early 70s were narrow.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 08-23-2014, 11:09 AM   #10
Wizo
Wizo's Avatar
Too much stuff; Yes its wider because i measured it against the 68.
NC67Chev: My truck has 71 disc breaks. I cut the 71 frame off just before the vin # underneath the cab and grafted it to my 68 frame. this way i can retain the original vin# of the 68. I would really to use 295/50R/15's out back and still get them inside the fender. shortening the axel is no problem. i just was wondering if i can get shorter inner axels. Tks
Old 08-23-2014, 11:22 AM   #11
Grip
Grip's Avatar
Wizo,
Companies like Moser will make axles in any width you need. CCP makes 5 lug axles for the 67-70 width axle housing so you have options.
Eric
68 Anniversary Gold C-20 LWB to C-10 SWB build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=637492
It's hard to explain puns to kleptomaniacs because they always take things literally.
Grip is offline   Reply With Quote
Old 08-23-2014, 12:28 PM   #12
Wizo
Wizo's Avatar
Grip; i will google them. tks
Old 08-24-2014, 12:26 PM   #13
70CHEVYBB
70CHEVYBB's Avatar
does anyone have the dimentions of both? axle flange to axle flange
Thanks, Wes
70CHEVYBB is offline   Reply With Quote
Old 08-25-2014, 09:01 AM   #14
volksworld
my leaf spring 70 was the wide one...when the ring and pinion went bad,i put in a 76 rear...and the 70 6-lug axles went right in
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 10-13-2014, 06:26 PM   #15
kitsbeach
kitsbeach's Avatar
Thanks, Wes
I'm interested in this too because I want to order conversion axles for my '67 but want to make sure I still have the narrower diff installed.
Mine is 57" from backing plate to backing plate (at the bend in the tape. It's not that obvious in the picture).
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 12-17-2014, 07:12 PM   #16
BarryV
Thanks, Wes
Reviving an old thread ...
I didn't find an answer to this question from Wes. I want to order axles BEFORE I take them out of my 1970 GM corporate 12 bolt. I am preparing for the holidays ... Merry Christmas ... and don't have time to take it apart at the moment.
How do I know if I have the shorter or the wider rear end? I will measure mine and post it later.
Thanks in advance,
Barry
BarryV is offline   Reply With Quote
Old 12-17-2014, 07:54 PM   #17
70CHEVYBB
70CHEVYBB's Avatar
I bought my new dorman axles that have bearings with them for 102.00 an axle free shipping on ebay. outside of flange to end of axle is 31 5/16 . dorman number is 630-128 this is for the wider of the two rear axles.
Old 12-17-2014, 08:11 PM   #18
BarryV
Thanks for that info. I was looking at that one earlier today.
Looks like my question was not stated correctly (or at least it was stated poorly!).
How can I tell if I have the narrow axle HOUSING or the wider axle HOUSING without removing the axle SHAFT and measuring it?
Thanks!
Barry
Old 12-17-2014, 08:26 PM   #19
BarryV
Mine is 57" from flange to flange, not counting the width of the flange. I am calling the flange the place where the backing plate attaches.
Barry
Old 12-18-2014, 09:37 AM   #20
70CHEVYBB
70CHEVYBB's Avatar
axle width is 55.5 wide with 30.5 long axles on the narrow rear end. earlier rear end
axle width is 57 wide with 31 5/16 long axles on the wider rear end. later rear end
Old 12-18-2014, 12:05 PM   #21
BarryV
Thank you Wes! Got mine ordered today.
Barry
Old 12-25-2014, 12:48 AM   #22
kitsbeach
kitsbeach's Avatar
Where you measuring from..axle flange or backing plate.?
Kitsbeach (Ken)
Old 12-25-2014, 11:46 AM   #23
bonnieclyde100
if you have not already got your wheels all you have to do is get wheels with a specific back spacing and you can set the wheel where you want it in the wheel well instead of cutting your axle.
bonnieclyde100 is offline   Reply With Quote
Old 10-11-2023, 02:09 PM   #24
Mav
Mav's Avatar
Have late build 70 K10, (7-10-70) Janesville Wi. Rear is 1 1/2 inches narrower than front.
Mav is offline   Reply With Quote
Old 10-11-2023, 05:16 PM   #25
'68OrangeSunshine
'68OrangeSunshine's Avatar
I found this out when I cannibalized the '67 rear-end from my '67 K/10 Suburban for my '71 GMC K/1500 Jimmy. Both were 3.73.
The shorter '67 rear [w/ Auburn Posi] was shoe-horned onto my '71 Jimmy. Running very nicely since 2010.
The wider OEM '71 Eaton Posi rear which ''lunched'' is currently hanging under the '67 Sub, but we were unable to fit it completely on. There's some baling wire involved. Not a problem as the Sub is not a runner. It's a Someday Project.
To resurrect the Sub, I would have to get the Eaton Posi rear rebuilt, then trade it out onto the Jimmy, and having pulled the Auburn Posi rear off the Jimmy, ire-nstall it on the Sub.
Not happening anytime soon.
