08-23-2014, 08:12 PM | #1 |
Replacing 1967 C50 wheel studs?
Anybody know where to find them and how they are removed from the front and rear? Is it too hard to do myself?
08-25-2014, 11:44 PM | #2 |
Re: Replacing 1967 C50 wheel studs?
I had to do a front one on my c60. actually pretty easy. pound out or use a good air hammer. I was able to install the new one with the wheel on, through the hand hole, and tighten it into place by torquing the lug nut down
08-26-2014, 12:41 AM | #3 |
OK, now the fun part, where did you buy the thing? Thank you for the reply, sounds not to bad after all.
08-26-2014, 12:56 AM | #4 |
I got mine at "6 robblees" I noticed there is one in oakland. but other trailer or truck repair parts houses. I think napa would have them
08-26-2014, 01:05 AM | #5 |
Be careful on trying to pull the stud in with the lug nut. You may overtorque the nut. It is best to press them in.
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
08-26-2014, 01:19 AM | #6 |
At the body shop.
Betts spring should be able to get one
" That didnt make it any newer " " Dont antique the equipment " |
08-26-2014, 01:26 AM | #7 |
I have always pulled them in with the nut just dont use a impact or cheater bar. frequently check that the head is seated then torque to proper specs.
08-26-2014, 01:27 AM | #8 |
I did strip one. that was when I was using a torque multiplier, it took about 400 foot lbs to strip it with a 60x torque multplier.
08-26-2014, 09:33 PM | #9 |
What is the torque spec for lug nuts on these big trucks?
Thank you to everyone for the help. |
