Old 02-05-2015, 11:10 PM   #1
Chrysis
Chrysis's Avatar
Accesory drive interchange question
Will the acessory drive from a Gen II pre 2003 5.3 work on a gen III L33 engine? Power steering, alternator, etc.? I got the engine cheap without the acessory drive, and I don;t want to spend as much on the drve as I did the engine. LOL
Any good (read cheap) ideas?
I tried searching but I must not be using the right terms.
Chrysis is offline   Reply With Quote
Old 02-06-2015, 10:23 AM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Accesory drive interchange question
First off, a Gen II is the old school EFI LT1. For truck engines (4.8, 5.3, 6.0) Gen III is anything from 99-07
Secondly, all the accessories are modular and interchangable. There are some mods that must be done sometimes to correctly utilize different accessories. For example, 4th gen F-body accessories require a bolt hole that does not exist on an iron block truck engine. The boss is there, you just have to drill and tap it. There are some variations, but for the most part, unless you really know what you're doing, you'll need to keep the water pump matched with the rest of the accessories, to keep the ofset from the block the same, and the pulleys all on the same plane.
You can get crazy with it if you want though...I've swapped a truck pulley to a camaro pump and run it with truck accessories in the past.
Go to the junkyard and find the accessories off of a junk LS truck. I can get them in my local junkyard for $50-100
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 02-07-2015, 02:33 AM   #3
Chrysis
Chrysis's Avatar
For some reason I was thinking the Gen III engines didn't start until 2002. Yeah, there are loads of 99-2002 trucks all over my nearest pick n pull. They never seem to have anything newer.
As long as the accessories from a 99 - 2007 truck will work, I'm good.
Thanks!
