02-27-2015, 09:15 AM | #1 |
700R4 driveshaft question
Hey guys,
I got the 700r4 installed in my 72 lwb but now the issue is the 2 piece drive-shaft that came with the new trans. The section between the trans and carrier bearing cross member is shorter..can I just move the cross member like I did for the trans? What's the best way to measure how much to have removed from the back section of drive shaft? Thanks |
02-27-2015, 11:19 AM | #2 |
Re: 700R4 driveshaft question
I figured out how to measure it.
02-27-2015, 11:24 AM | #3 |
just switched my sm trany to a 2004r in my 67 , I just cut the front shaft down and had a driveshaft shop weld and balance it ,, it is completly diferant than yours though ,, the carrier bearing mounts to th bottom of the crossmember with a flat bracket that is riveted to the two empty holes in your picture , my truck is a coil spring truck so the swing arms connect there also . A one piece driveshaft is and option for you also as the 700r4 is longer therefor making your driveshaft shorter ,, posably within the length of an inexpensive one piece ,, i think around 59 inches ,, longer than that and they start wanting you to start useing 3 1/2 inch diameter shafts
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive Last edited by 67 chevelle; 02-27-2015 at 11:31 AM. |
02-27-2015, 11:25 AM | #4 |
I did the same with the 700 in my Longhorn. I had the front shaft shortened at the slip yoke end. Rebalanced and rock and roll.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
02-27-2015, 12:10 PM | #5 |
So the slip yoke end is easiest to shorten?
