Old 02-27-2015, 12:28 PM   #1
bnoon
LS swappers, engine mounts, what did you use?
Many different LS engine mount adapters out there. Which ones did you use? Would you use them again? Any modifications needed?
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 02-27-2015, 02:56 PM   #2
Rich84
Rich84's Avatar
Re: LS swappers, engine mounts, what did you use?
Lurking...
Rich84 is offline   Reply With Quote
Old 02-28-2015, 10:27 AM   #3
bnoon
Seriously? Nobody?
Old 02-28-2015, 11:27 AM   #4
mattcrp1
mattcrp1's Avatar
I used Dirty Dingo sliders with factory clam shell rubber mounts. I had to remove the a/c compressor to fit the engine in the right spot.
My Chevy habit is paid for by Ford diesels...
Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355
Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748
Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974
IG mattcrp1
mattcrp1 is offline   Reply With Quote
Old 02-28-2015, 12:51 PM   #5
bnoon
Thank you.
Old 02-28-2015, 03:01 PM   #6
Blazr77400
Here is a set that I built for mine. It pushes the motor back so there is no crossmember modification. The bushing assembly is from ORD. I used the 2" bushing with 9/16" bolt. I should still have the water jet file if anyone needs it.
Blazr77400 is offline   Reply With Quote
Old 02-28-2015, 03:03 PM   #7
Blazr77400
Some more.
Old 02-28-2015, 05:07 PM   #8
bnoon
Which pan were you using that you would have had to modify the cross member?
Old 02-28-2015, 05:14 PM   #9
bnoon
I just ordered the Dirty Dingo ones. I liked the idea of being sliders to adjust to what I need. I saw three position mounts for half the price of the Dingos, but knowing my luck it would be halfway between two of the positions that I would need. Thanks for the feedback!!!
Old 02-28-2015, 06:01 PM   #10
solidaxel
solidaxel's Avatar
Same for me on my 78 5.3/4L60E
I was able to slide the engine back to line up the drive shaft and the stock shift linkage and only had to drill some new holes for the stock cross member which moved to the rear about 3"
I also used new stock chassis rubber mounts
I also bought the D Dingo Sanden A/C bracket
All works great
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 02-28-2015, 07:09 PM   #11
bnoon
When I add AC back, I will do that for sure!!! Did you have to get custom hoses or did a combination of factory hoses work?
Old 02-28-2015, 11:58 PM   #12
Tilt
I'm also using the Dirty Dingo sliders with the factory clam shell mounts. I have the motor slid roughly half way back. I just test fit a set of Schoenfeld long tube headers (1302LS1) and they look like they fit great and clear everything.
'83 Silverado Step Side
'85 GMC short bed.
'86 Chevy Step Side Custom Deluxe
LQ9/4L80 swap (SOLD)
Tilt is offline   Reply With Quote
Old 03-01-2015, 09:04 AM   #13
solidaxel
solidaxel's Avatar
YES they were a custom combo. and some of the stock pieces were used.
many trips to the A/C store !!
LS 3 4L70E
Old 03-06-2015, 02:42 PM   #14
tpankratz
I would like a copy of that water jet file if you still have it. I have a water jet at work and am getting ready to drop a 5.3 in my 79. What trans did you use, and did you have to modify the driveshaft to fit?
tpankratz is offline   Reply With Quote
Old 03-06-2015, 10:42 PM   #15
Blazr77400
Give me your email address and I can send them to you.
I'm using a 4l80e. Mine is 4 wheel drive and I totally redid my transfer case and crossmember for it. With my mounts you could probably bolt the plates up, space the motor and trans so it will bolt up, then weld the mounts up.
