Old 02-28-2015, 09:43 AM   #1
StrokinRat
StrokinRat's Avatar
What duel electric fans are you guys running?
I'm about to start tearing the front end of my motor down to fix a leak around the timing chain cover ( also get rid of the gear drive that I thought was cool a few years ago but now it just gets on my nerves). Anyway I want to add duel electric fans. The truck has a over sized radiator already. Any help and/or pictures would be appreciated.
85 Chevy C-10 383 stroker
StrokinRat is offline   Reply With Quote
Old 02-28-2015, 12:18 PM   #2
greg64
greg64's Avatar
Re: What duel electric fans are you guys running?
On my suburban, I'm using Derale dual fans.
http://derale.com/products/electric-...ual-powerpacks
They work well, and aren't loud. I needed a fair bit of airflow because I have limited rad area on the 64, and I was towing a 3500# enclosed trailer for 500 miles on 85+F days.
On my 77, I'm using dual fans out of a chevy sprint. Cost me $20. Then I made up a bracket to hold them. Those fans are still working today, and they've been on my truck for 15 years, and the Sprint was clapped out when I swiped them from the junkyard. These don't move the air of the Derale, but they do work.
Oh, and I had to redo my suburban fans. I started out with a 16" single with no shrouding, but that didn't cut the mustard.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 02-28-2015, 12:40 PM   #3
Slammed84
Slammed84's Avatar
Theres a forum member named Gmachinz.... he makes some really cool setups for electric fans. He can help you out and keep the cost down.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 02-28-2015, 03:28 PM   #4
tucsonjwt
I got a pusher fan from a Geo Metro because the mounting frame fit nicely in front of the one side that was open in front of the A/C condensor. The other side had the factory oil cooler in the way. Without the oil cooler, I suppose that two Metro fans would have worked. I wanted extra cooling for the condensor, so I wired it into the power circuit for the A/C compresor - it turns on when the compressor turns on. It is much better than A/C cooling without it, but 134A with the old factory condensor limits A/C performance.
tucsonjwt is offline   Reply With Quote
Old 02-28-2015, 05:57 PM   #5
Blazr77400
I have had really good luck with the late 90s Ford Windstar Van Fans. They are cheap from the junk yard, but can be bought online for around $90. I have used them on a 6.2 diesel, a Small block chevy, Big block chevy, and now the LS with great results. Each fan can be wired separately if wanted.
Blazr77400 is offline   Reply With Quote
Old 02-28-2015, 06:09 PM   #6
Titomars
Titomars's Avatar
What years and what engine does the Windstar fans come from? Is that the factory Ford shroud unit? Because it looks almost bolt in.
1977 Chevrolet C/10 Silverado. Step-Side, Factory 454, TH400, 3.73 Posi 12 Bolt.
1975 Chevrolet El Camino. 350, TH400, 3.08 Posi 10 Bolt.
Titomars is offline   Reply With Quote
Old 02-28-2015, 06:26 PM   #7
Blazr77400
I just looked on RockautoIt .com under a 1997 with a 3.8.
It looks like all Windstar Vans from 1995 to 2003 came with the same fan assembly.
Yes that's the factory shroud with the tabs cut off and holes cut for the hoses.
Old 02-28-2015, 07:28 PM   #8
bnoon
Those look really slick!!!
- 1981 Sierra 454, NV4500 swap
- 2006 Z06, 25k miles
- 1973 Nova - Project CarNova Virus on Youtube
bnoon is offline   Reply With Quote
Old 02-28-2015, 10:42 PM   #9
Titomars
Titomars's Avatar
cool and thanks. It looks like I just found my electric fan package for my 454.
Old 02-28-2015, 11:28 PM   #10
gmachinz
Seeing as how you're in the muggy Mississippi, you might want to look (since you say you have an oversized radiator...?) at 2010-up F-150 dual fans. They are 38x18x6 and together on high speed move approx. 6000 CFM. I've built one fan kit using them with my 3-speed universal fan conversion harness with good results. It moves more air than anything you'll ever find and I stock NEW Motorcraft units if interested. I buy them in bulk so I can price them below retail cost from the dealer-PM if you want install details.
gmachinz is offline   Reply With Quote
Old 03-01-2015, 04:18 AM   #11
chevy-fun
chevy-fun's Avatar
Sub
chevy-fun is offline   Reply With Quote
