03-26-2015, 08:04 AM | #1 |
Brake booster size help
ok guys got a 67 c10. I'm trying to swap from an 11" booster to a smaller dual diaphragm and need some help . with a BBC in there the 11" booster barely fit so I wanted some more room.
Front brakes- converted to 5 lug with stock gm disc brakes rear- stock drums. all totally new. prior to now the truck has the stock booster setup from the a 72 disc brake truck. last fall I bought a capt fab bracket to mount the booster closer to firewall. I also decided to upgrade to a dual diaphragm booster I put a Wilwood master cylinder and adjustable proportioning valve kit on an 7" dual diaphragm booster. Is a 7" dual diaphragm booster enough, or should I use an 8" dual diaphragm? I've found some things online that said to calculate the surface area of the booster, and if you do that: 1-assume the factory is a true 11" booster (my measurements put it closer to 10") 11" booster- surface area of 95 8" dual booster- 100 2- if you factor in the factory booster does not actually have 11" of actual area 10" booster- 78.5 7" dual booster- 77 however, for the brand of booster I purchased (Tuff Stuff Performance) jegs website list 7" as disc/drum and 8" as disc/disc. any help here would be great. If I can use the 7" dual I would prefer as it gives me the most amount of room |
03-26-2015, 09:56 AM | #2 |
Re: Brake booster size help
booster size will be determined on the amount of vacuum the engine produces,if you post this then it will be easier to advise.
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
03-26-2015, 01:46 PM | #3 |
03-27-2015, 07:46 AM | #4 |
I was having trouble getting a vacuum reading last night.
BBC with no choke does not like to idle cold. my vacuum reading was around 12-15. rev it up a bit to say 1500 and I could see it jump up. Right now I have the 7" dual diaphragm installed and it seems to work fine. I didn't want to pull out of the garage since it was raining last night, so I put the truck in reverse and let the clutch out, truck doesn't budge an inch and stalls. I think I'm ok with the dual 7. my only actual issue is that it seems like I have TOO much assist, in that my pedal gets really soft once the truck is running. maybe I just need to get used to the new booster |
