Old 03-26-2015, 04:30 PM   #1
still1graphics
Help Decoding a Inline 6 engine code??? 230 or 292
Hi, i am having trouble finding out what size my engine is??? It came out of a 69' chevy c10 pickup. Any help would be greatly appreciated!!!!
#'s on the side of the block:
F0424PP
I was told it is the original motor out of this truck??? But i can't figure out what size it is?? 230 or 292..... or something else???
still1graphics is offline   Reply With Quote
Old 03-26-2015, 05:15 PM   #2
russgoodman
russgoodman's Avatar
Re: Help Decoding a Inline 6 engine code??? 230 or 292
It will either be a 250 or a 292. Look at the fuel pump - if its in front of the pass side motor mount its a 250.
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554
2008 GMC Sierra Denali - 6.2L AWD - my daily
2011 Ford Flex Limited - Ecoboost AWD - wife's daily
1987 Buick Regal Turbo T - 63K miles - Strip/Street car
1965 Ford Mustang Coupe - 289, c4, 53K miles
russgoodman is offline   Reply With Quote
Old 03-26-2015, 05:21 PM   #3
lowrodderchev
lowrodderchev's Avatar
not sure on the 230 but the 292 has a taller set of side covers
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 03-26-2015, 06:50 PM   #4
still1graphics
I also have this one I'm trying to figure out?
It's in my 63' chevy c10 Truck.
Inline 6.
Please help me figure this engine size out along with my
Other motor in my 69' (# above)
Thanks for the help! !!
Old 03-26-2015, 08:35 PM   #5
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
You might try reading this page, it wasn't great help on my 2 I-6 engines, but I did learn a little bit about them. Also reportedly the number cast into the block behind the dipstick is the date the block was cast. For instance the one in my '55, which I believe is a 230, has K 9 4 cast there. K is the 11th number of the alphabet so that means November. 9 means the 9th of the month and 4 probably means 1964 but it could mean 1974 but I don't think so since I think it is a 230.
http://www.novaresource.org/codes.htm
Hope this helps. DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
Old 03-27-2015, 10:42 AM   #6
mr48chev
mr48chev's Avatar
As a couple of the guys said the location of the fuel pump is the quick positive indicator of a 292 compared to the smaller engines.
I can't find my 250 engine photos right now but this is the right side of the 292 destined for my 48. Note that the motor mount is between the fuel pump and distributor and the just over six inch height of the side covers.
Also the 292 usually has a large bypass hose from the head to the fuel pump
That you don't see on the smaller engines.
Left side of 68 292.
Here is a listing of many Chevrolet six cylinder casting numbers that is worth bookmarking
http://www.adchevy.com/info/6-cylind...asting-numbers
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 03-27-2015, 02:36 PM   #7
OrrieG
OrrieG's Avatar
Pretty sure that bi-pass hose goes to the water pump....
OrrieG is offline   Reply With Quote
