08-30-2003, 09:26 AM | #1 |
Resistor-Dumb question
I pulled the heater/AC control to replace the fan switch. I also replaced the relay behind the glove box. Vendor said to replace the resistor at the same time. Where is it? Told you it was a dumb question. TF
08-30-2003, 02:19 PM | #2 |
huh?
I *think* the resistor he is referring to is the three-pronged thingamabob on the heater/ac box. But I could be wrong.
TTT
Someday when I'm lonely, Wishing you weren't so far away, Then I will remember Things we said today. RIP El Jay |
08-30-2003, 02:47 PM | #3 |
Inline 69
is this the"thing-a-mabob"
08-30-2003, 04:46 PM | #4 |
Resistor Connection
Jeff 5150, Any chance that has 2 blue and 2 yellow wires on the plug? If so, it's inside the box, no wonder I couldn't find it. Tfrog
08-30-2003, 09:30 PM | #5 |
per 1971 GM Manual.....the resistor pack has 3 wires....Dark Blue; Light Blue and Yellow.......
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
08-31-2003, 12:26 AM | #6 |
The resistor controls the fan speeds, if you are replacing the switch because of melting connectors there is too much resistance in the blower motor itself, thus creating heat.
08-31-2003, 07:00 AM | #7 |
I found it
Thanks to all, class 69 GMC Jim, 5150 et al. Unfortunately I got the duct work apart before I go the last post, but I'll change it while it's on the floor now. Thanks for the directioin and for the drawing. I owe you. TF
