04-20-2015, 09:53 PM | #1 |
Gentleman Jim owner x2
New engine and some questions
How do you attach accessories to an engine with camel/double-hump heads? I just brought a nice sbc 358 home with me, paid a song and dance for it (at least I think so) and the guy said all I had to do was find accessory mounts. I'm just curious as to where I should be looking.
Also, the guy I got this from said there is a "short" and "long" water pump, and that I have to match the accessory mounts for the water pump. Any idea what I should be looking for on that one?
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
04-20-2015, 10:15 PM | #2 |
Re: New engine and some questions
Brackets available here.
http://www.alangrovecomponents.com/ To check for the pump difference, just look between the back of the pump and the timing cover. A short pump has only 1/4 inch wide distance whereas a long pump is closer to 3/4 inch. |
04-20-2015, 10:16 PM | #3 |
Great, thanks. I don't have a water pump at all for it yet. So I guess I just match up whatever I choose to use? Or is there an advantage to using one over the other? I do plan on running a/c in my truck if it matters.
Posted via Mobile Device |
04-20-2015, 11:04 PM | #4 |
Depends where you want your a/c, altenator and ps pump.
The long pump allows the altenator to tuck in low in front of the passenger side head. PS pump in it's normal location and a/c up top. You'll need to get some ideas of the best set up from that link. |
04-21-2015, 02:31 PM | #5 |
Are there any other options that aren't going to cost me $250 for 3 brackets?
04-21-2015, 02:51 PM | #6 |
Short water pumps are for older Chevy like 65 and older get long water pump.
83 c10 long Box Daily Driver 90 Jimmy parked 98 Road King/ 06 Road Glide In memorium 63 impala SS/ 65 Chevy Panel 65 GMC Short Box/ 68 Camero |
04-21-2015, 03:02 PM | #7 |
04-21-2015, 06:23 PM | #8 | |
04-21-2015, 10:27 PM | #9 |
There is always the nice looking chinese stuff if you don't want to spend a lot.
http://www.skipwhiteperformance.com/...x?Item=P-44302 I have seen low mount alternator brackets too but I can't remember where right now,maybe ebay.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
