04-23-2015, 12:52 PM | #1 |
Stock exhaust manifold help - will Nova maniflds fit?
I have a 79 k10 with a stock 350 in it. Im looking for some exhaust manifolds with the A.I.R tubes because its a CA truck.
Seen some exhaust manifolds on Craigslist, the guy says they are off a 72 Nova. Will they fit ok? It looks like they will, I was just wondering about the down pipe or Y pipe part if that will match up? What do you guys think? here is what they look like: |
04-23-2015, 02:23 PM | #2 |
Re: Stock exhaust manifold help - will Nova maniflds fit?
Those should fit and suffice the smog inspection but hard to say if they will match up to the Y pipe without seeing which kind are on your truck now.... Worse case is you have a exhaust shop make up a new Y pipe. Make sure you have the heat riser valve also that goes on the pass side manifold. Need that to pass visual also.
04-26-2015, 11:53 AM | #3 |
They will fit. I use my '73 Nova manifolds in my '83. And I am assuming you know that you just ain't going to bolt up the exhaust pipes if you have the overthesparkplugs manifolds now.
Alex. |
