05-31-2015, 04:50 PM | #1 |
power steering pulley
I know I could not be the only one to think this but could not find anything about it... Drilling access holes when needing to remove power steering pump. I don't know if it will throw off the balance or what.. And yes it's all metal
05-31-2015, 10:52 PM | #2 |
Re: power steering pulley
If the holes were needed the factory would have put them there. Front wheel drive gm cars had access holes but trucks need a puller to remove it. The pulley should have a groove in the nose area for the puller to latch onto it. Do a google search on gm power steering pump puller and you will be able to see if this is whats needed.
05-31-2015, 11:20 PM | #3 |
GM does a lot of things that don't make sense some times... I was just asking if it would effect it working properly...
06-01-2015, 12:17 AM | #4 |
Balance at high RPM would be a problem if they were not the same
Are there some steel pulleys that have three spokes, and access to the bolts available without removing the pulley
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
06-01-2015, 12:44 AM | #5 |
Ok thanks...
06-01-2015, 07:56 AM | #6 |
Just drill your hole what you need and then drill another on the opposite side to counter balance . Doubt it will hurt the integrity at all . A lot go gm pulleys have lots of holes in them.
06-06-2015, 11:00 AM | #7 |
there's a bunch of options with holes. search on ls1tech about PS pulleys and there's 3-4 dorman part numbers and some JY stuff too.
06-06-2015, 07:07 PM | #8 |
If your worried about balance drill 3 equally spaced holes in the pulley. If balance was an issue the belt yanking on the pump in one direction would cause all sorts of problems. A ps pump pulley puller isn't terribly expensive though.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
