06-23-2015, 09:46 AM | #1 |
Head Gasket Question
I have the dreaded, leaking 706 heads. There's water coming out one of the header bolts. It's no pouring out, but it is leaking slowly. There hasn't been any water in my oil - I've been keeping an eye on that - but I wanted to swap these out before I ran into more problems.
My buddy gave me a set of 862 heads that were part of a deal when he bought a truck. They were on a boosted motor that had been disassembled. They've had the gap filled and the face machined so that they could run LS9 head gaskets. (see picture for reference). From what I gather, those gaskets have a bigger bore, but hold up better in boosted motors. When I swap these into place, should I pick up a set of LS9 gaskets, or will I be OK with the stock 5.3L gaskets since I don't plan to do anything else to this motor? While I'm at it - what's the input on these eBay gasket kits that have all the gaskets and the head bolts for like $120? Thanks - Matt
Matt Criswell - Lyman, SC 1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE |
06-25-2015, 09:45 PM | #2 |
Fabricate till you "puke"
Re: Head Gasket Question
Look at the yr on the heads/vs gaskets? My 2000 5.3 had the notch that you see on the heads....on a 400 dollar valve job, I don't think there was any welding going? The heads were, no notch smooth / flat....yes he cut .060-.070 off my heads! Thank you "Scotty".. she burns pump fuel, idles like a stock ride, & will twist that old longhorn loose/ sideways at will....with 140 thou on the 5.3 shortblock! Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
06-25-2015, 11:38 PM | #3 | |
meowMEOWmeowMEOW
I wouldn't trust no-name hardware for anything that goes into the aluminum heads. I don't trust chinese piston rings either for that matter.
06-29-2015, 10:46 PM | #4 |
Yes, I run ARP bolts in my old ride....very expensive on top, but useable 3 or 4 times again! The flywheel/clutch hat bolts, from ARP are as cheap, as the TTY chit from the factory, & you can reuse the bolts...longhorn
06-29-2015, 11:12 PM | #5 |
"706" heads do not leak out the exhaust manifold bolt holes, The develop cracks in the head bolt bosses, Only certain "Castech" castings did that. Compared to shear numbers of 5.3L produced with "706" heads...Actual failures are rare.....
Some dimwit drilled to far to remove a broken manifold bolt...Is what happened. |
06-30-2015, 04:44 AM | #6 | |
It's alsways something.....
Seems like every engine I check out for donors has at least 2 broken and usually the rear on the driver side.
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
06-30-2015, 09:44 AM | #7 | |
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
06-30-2015, 12:37 PM | #8 |
gm head bolts are fine and inexpensive, unless you intend on taking the heads on and off multiple times. then you should bite the bullet and use studs anyways.
i would use a replacement mls 5.3 gasket and call it a day.
1999 GMC Suburban K2500 SLT, 454/4L80E 1991 Z/28, 6.0L/T56 1949 GMC 250, S10 Frame, 6.0L/4L80E Instagram @aceshighspeedshop |
06-30-2015, 07:46 PM | #9 | |
However....I'm not the one who damaged his cylinder head, Wasn't there when it happened, But that is the only way for coolant to leak from a manifold bolt. I would drain the coolant down, Put some Red "Gel" Loctite on the bolt, Torque it down & wait 24 hours, Refill with coolant & call it a day. |
06-30-2015, 08:14 PM | #10 | |
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded '03 burb. Family cruiser http://upstategmtrucks.com/ |
06-30-2015, 08:18 PM | #11 | |
06-30-2015, 09:22 PM | #12 | |
06-30-2015, 09:25 PM | #13 | |
Thanks for the input everyone. I have my doubts that a "dimwit" drilled too far into the head. There were two broken manifold bolts that my buddy (bluex) did drill out, but they aren't the one's leaking. In both cases, neither bolt was drilled all the way through, so there's no chance he drilled too deep. And afterwards, we visually inspected each hole, and there was no visible damage. I deal with porosity issues on a regular bases. My company represents about a dozen valve manufacturers, and I've seen casting issues in just about every material valves can be made from. I'm not 100%, but I'm pretty sure my heads are failing due to a porosity issue due to a flaw in the casting process. Regardless, it would have been nice if you helped with my questions rather than pointed out that my evaluation was wrong. Your comments, while potentially educational, failed to help with my current issue or basis for my post. Thanks to Br3w City & Outlaw Drifter for the helpful responses.
06-30-2015, 09:31 PM | #14 |
No Matt does, and I drilled the broken studs out for him when he got the engine from the salvage yard.
06-30-2015, 09:39 PM | #15 |
Like Cline already said the 706 heads that have issues are a select batch of Castech heads and leak from the head bolt area.
I think you guys are taking the dimwit comment to heart, but more than likely "someone" maybe not you guys drilled too far. This happens all the time with these heads and isn't hard to do if you don't pay attention. On to helping with a solution, either do what Cline said and throw some loctite on the bolts and let it dry or toss the heads and get another set. These heads are all over the place for next to nothing. Not even worth the time discussing it much further.
06-30-2015, 09:43 PM | #16 |
Oh and to clear it up further here is the gm tsb for the issue http://ww2.justanswer.com/uploads/Bl...t_loss_5.3.pdf
06-30-2015, 09:47 PM | #17 |
What number loctitie are you guys referring to because the red I know of isnt a thread sealer and will only make future removal of the bolts even worse.
06-30-2015, 09:51 PM | #18 |
06-30-2015, 09:52 PM | #19 | |
And being that I took the new heads to the machine shop yesterday (after waiting a week for help from the forum), there's really no need to keep discussing the matter.
06-30-2015, 10:18 PM | #20 |
What heads are at the machine shop? Also with the notch welded on the 862 you can run the LS9 gaskets. If it's not boosted you can also run the stock gaskets and be fine. That should answer your initial question. If it was me I would buy the stock ****, head gaskets and bolts.
As for why all the discussion about the leaking heads, 2 things. First was to make it clear for any future readers your leaking issue had nothing to do with the known Castech head problem, second was to give you an easy way to fix the heads you had that were leaking and for anyone else that may have drilled too far. I think you guys took the name calling a little too personal, especially if you didn't even touch those holes lmao!
06-30-2015, 11:04 PM | #21 | |
07-01-2015, 12:14 AM | #22 | |
You got this idea that "706" heads have issues from the internet, Then made up your own hypothesis that they will & can leak from the manifold bolts due to porosity....Good, It can still be fixed with Loctite. |
