Old 07-13-2015, 12:14 PM   #1
creep
Registered Loser
creep's Avatar
Window Track Mount Help Needed.
On my driver side door the weldnut that holds the window track bracket to the inside of the door broke loose and now the braclet is flopping around inside the door. Does anyone repop these parts? It is the bracket that is inside the door on the back edge by the striker. It is held in by screws going into the outside edge of the door. I will try to get pics later today.
'63 GMC lwb, 383, th350, lays frame, genuine patina.
The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267
'88 Astro cargo bagged, shaved, phantom grille. *SOLD*
'50 Chevy 2 door sedan awaiting attention.
2014 Silverado Ext cab, 5.3, daily driver.
creep is offline   Reply With Quote
Old 07-13-2015, 12:37 PM   #2
1963c-10
1963c-10's Avatar
Re: Window Track Mount Help Needed.
Sounds like this piece....and its not reproduced. You'll have to source a used one. This is a driver side I just got rid of. I'd try the classifieds with a want to buy listing.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 07-13-2015, 12:47 PM   #3
63burban
Chevy addict
Weld or braze the nut back in, could even use JB weld.
If not, I probably have a good used one I'd get rid of.
63burban is offline   Reply With Quote
Old 07-13-2015, 03:34 PM   #4
creep
Registered Loser
creep's Avatar
Thats the piece.
I guess I'll take it out tomorrow and see if I can get the nut tacked back in.
Thaynks guys.
Old 07-13-2015, 04:28 PM   #5
1963c-10
1963c-10's Avatar
May be a good option to try a riv nut.....depending on how the old one came off.
Old 07-13-2015, 04:40 PM   #6
Figuarus
Figuarus's Avatar
try this...
http://67-72chevytrucks.com/vboard/s...d.php?t=667671
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 07-13-2015, 06:28 PM   #7
creep
Registered Loser
creep's Avatar
Originally Posted by Figuarus View Post
I may have to try something similar to what you did. Mine broke on the top end and it looks like it had already been re-welded once before.
Old 07-14-2015, 08:24 AM   #8
1963c-10
1963c-10's Avatar
Yeah...riv nut would only work if a new piece was welded in and a new hole drilled to accept it.
Old 07-15-2015, 08:54 AM   #9
creep
Registered Loser
creep's Avatar
Here's what I came up with...
Seems to work great. The window goes up and down easier and for some reason my door even opens and closes easier now too.
Old 07-15-2015, 08:57 AM   #10
1963c-10
1963c-10's Avatar
Glad you got it resolved Creep!!!
Old 07-15-2015, 10:48 AM   #11
Mathew21
Mathew21's Avatar
Nice job creep!
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 07-16-2015, 11:46 AM   #12
creep
Registered Loser
creep's Avatar
Thanks guys.
