Old 08-07-2015, 08:54 PM   #1
Cautrell05
Door latches
Sill in the planning stages off my 47 build. So far I got it home and off the trailer. I will start a build thread when I actually get to work on it.
Because my wife and kids will be driving it at some point I need to make sure the doors stay shut. I see the term bear claw used a lot. Is that just another term for modern style latches?
Cautrell05 is offline   Reply With Quote
Old 08-08-2015, 08:46 PM   #2
Lo1dakota
Lo1dakota's Avatar
Re: Door latches
Essentially. Google it. You'll find out
Lo1dakota is offline   Reply With Quote
Old 08-08-2015, 09:01 PM   #3
Advanced Design
Advanced Design's Avatar
Re: Door latches
Another option is Altman easy latches. A little pricey, easy install and they work very well.
http://www.triquemfg.com/chevy-altman-easy-latches/
Advanced Design is offline   Reply With Quote
Old 08-08-2015, 11:50 PM   #4
Cautrell05
Re: Door latches
That's what I was kinda figuring. What I was kinda thinking since the door needs to be reworked anyway was using a set of latches from an 07 and up GM pickup. Fairly compact, door jamb switch built in and power locks. Thoughts?
Nick
Old 08-10-2015, 12:45 PM   #5
trucktech
Nick
The nice thing with the Altman latches are that they work with the stock handles. If you use any others you have to fab up your own
trucktech is offline   Reply With Quote
Old 08-21-2015, 11:59 PM   #6
99 to Life
99 to Life's Avatar
Re: Door latches
I made my own Altman style latches. I just used big bear claws and made some plates that bolted on. i'll be making some prototypes eventually to give out for guys to try. just haven't gotten around to that quite yet. The downfall is, if you have turn down handles, you can't use them, well... you might be able to if that is your goal. Mine wasn't on this one. so what I did was installed this actuator that is run off of the AVS keyless entry. I managed to get the interior handles to work.
it took me quite few hours to get it all mapped out. You really have to have some cracker jack timing cause the mech can hit the windows if your not careful. Overall I'm happy with it and I saved some loot, but.... lost out on time doing it. Though next time around I have templates and reference points.
I have a video of them in action if you want to see it.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
