10-22-2015, 09:43 AM | #1 |
What box you using with crossover steering
I have the captain fab steering plate and I'm converting to crossover. So I need a 2wd box. I also need metric fittings to work with my 95 hydrobooster. So should I be grabbing a 95 c1500 box or is there a better suggestion from the group?
10-22-2015, 10:27 AM | #2 |
Re: What box you using with crossover steering
I think you need to grab a 2wd box off a 91 and older truck. V style truck (square) not C style (88-up round body). I think after 1980 fittings were metric, but not 100%. I know they went metric in the 80s just not sure when.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
10-22-2015, 06:20 PM | #3 |
You are right - they did go metric in the 80's. Looks like any 91 and older square body is the ticket. Thanks!
10-23-2015, 12:41 AM | #4 |
Although now not sure if I can even go crossover. I dont have lift - or at least dont believe I do. Just 35's on a stock 65GMC
10-23-2015, 02:18 AM | #5 |
Do your front leafs look flat or arched up or are they arched down?
10-23-2015, 08:44 AM | #6 |
If it's a stock 4wd then they are arched. Just need to see how much clearance you have for the drag link. Even with no or low lift, think there is room underneath, but been 10 years since I had mine so can't remember....
10-23-2015, 10:33 AM | #7 |
My leafs do have arch. I think it can be done. Might have to do a little tube bending. Will post back when its installed. Currently deciding what to do about 1/2" width difference on the springs v. Dodge pads.
10-23-2015, 06:52 PM | #8 |
Been a while, but what is the difference between Dodge and GM?
10-23-2015, 07:57 PM | #9 |
6>8 Plugless........
Here's a link with a lot of good info. About half way down there's a chart showing specs and measurements.
http://www.pirate4x4.com/tech/billavista/60_front/ Also found this in another thread on Pirate 4x4. Post#6 The dodge is narrower by a little bit. The dodge has a 2.5 wide spring perch and smaller leaf spring studs with a different top plate. the dodge the parch width is slightly narrower. The dodge has a shorter short side axle and tube. The dodge knuckle has the cast in steering arm up higher than the GM. Theres a light and heavy Dodge brake caliper(not sure about GM). Nothing wrong with a Dodge D60 but it is a bit different than a GM. http://www.pirate4x4.com/forum/newbi...hevy-60-a.html The Dodge D60's also use 1/2" wheel studs instead of 9/16 like a chevy D60. But the knurl size is the same and a 9/16 stud can be installed in them. (On a 91-93 Dodge D60 any way)
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
10-23-2015, 08:40 PM | #10 |
The axles I remember, but not putting one in a GM. I think you can shave one side 1/4" and use a spacer on the other side....
10-23-2015, 09:36 PM | #11 |
Off road design sells off set spring bushings to fit the dodge dana in a gm
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
10-24-2015, 02:45 AM | #12 |
The reason for the dodge swap is people act like a gm dana 60 is made of gold and the dodge 60s are cheaper.
10-24-2015, 01:14 PM | #13 | |
Not sure if I should do a new thread - but does anyone know of a truck I could rob some 2.25" wide leafs from? This would give me the additional 1/4" clearance I need on either side. I would use a 1/4" spacer at the spring eyes to make up for the narrower leaf. Just don't know what truck in the yard to rob the leafs from that would work on my 65. |
10-24-2015, 01:15 PM | #14 |
Yeah my 92 dodge diesel axle with low miles was $250. The chevy version over $1000! Also I like that the dodge one is the same width as my rear so theres another plus for me.
10-25-2015, 09:18 PM | #15 |
If you want to see a insane price look at the 70s ford dana 60 front those are 1500 to 2500 depending who wants it bad.But those axles are used in a lot of sas swaps and jeep guys love them.
