Old 11-08-2015, 12:54 PM   #1
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Street Demon Feeder
A few years ago, when playing around with the intake, I changed over to a Street Demon 625 CFM on the 350.
I know they've had mixed (pun) reviews. But, since I got it all synched and metered out, I'm happy with it for now.
During that remake of the fuel system (tank to carb. Tank still in the cab on purpose), I added an electric fuel
pump that I'm running along the frame under the tank.
I thought the pump was rated for up to about 12 lbs psi. Demon calls for 5-6 at idle.
I'm using a decent fuel pressure "gate" with adjustments from about 3-20 psi.
The gage on the pressure regulator won't read more than about 3.5 psi all the way open. The truck runs great.
Except it starves under prolonged revs... or running up a grade when the trans kicks down (and revs increase) .
So, the question is, what electric fuel pump are any of you folks running that will feed my Demon properly?
Thanks.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline   Reply With Quote
Old 11-08-2015, 01:56 PM   #2
Waldoe
Re: Street Demon Feeder
My fuel pump is mounted like yours and it is a carter p4070. I just took off a 750 race demon and installed a 750 street advenger whish is when I checked the fuel psi. It was 6.5 psi. Hope this helps.
1970 GMC Sierra Grande Custom 2500
265/70/16, th400, 502ht
Waldoe is offline   Reply With Quote
