Old 11-15-2015, 03:56 PM   #1
RootBeerFXS
RootBeerFXS's Avatar
Caliper banjo bolts
Anyone have any luck with getting them at the local auto parts stores? Autozone doesn't have a clue, had to show them a picture. Oreally's has to order them. and is 7/16 x 20 the correct size for the early trucks?
RootBeerFXS is offline   Reply With Quote
Old 11-15-2015, 05:52 PM   #2
akart
Re: Caliper banjo bolts
My '82 K20 uses 10mm bolts. Rebuilt calipers are like 20 bucks, probably best to replace those old ones.
akart is offline   Reply With Quote
Old 11-15-2015, 06:28 PM   #3
enaberif
73-77 uses 7/16 and 78-> uses 10mm.
Nothing wrong with the old calipers but they could probably use a rebuild which would be far cheaper.
enaberif is offline   Reply With Quote
Old 11-15-2015, 07:45 PM   #4
Front Range
Front Range's Avatar
http://www.ebay.com/sch/i.html?_from...bolts&_sacat=0
Folks that throw dirt on you aren't always trying to hurt you, and folks that pull you out of a jam aren't always trying to help you.
Front Range is offline   Reply With Quote
Old 11-17-2015, 01:02 AM   #5
TheWhiteElephant
God is good!
TheWhiteElephant's Avatar
You can find them in the "Help!" section. Just saw them at Oreilly a few days ago.
Mando
"It takes a smart man to know when he's stupid." -- Barney Rubble
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=430367
TheWhiteElephant is offline   Reply With Quote
Old 11-17-2015, 09:39 PM   #6
russgt
russgt's Avatar
Yes, look in the HELP section. Autozone has them there too, no one working there had a clue.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 11-18-2015, 08:17 PM   #7
1970pelle
1970pelle's Avatar
Also Harley Davidson calipers use banjo bolts in 10mm and 12mm. With different style fastener head. Could get you out of a jam.
Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels
2007 Lexus ES350 (wifes)
1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift
“There is no limit to the amount of good you can do if you don't care who gets the credit.”
― Ronald Reagan
1970pelle is offline   Reply With Quote
Old 11-26-2015, 11:04 AM   #8
RootBeerFXS
Found them. For anyone needing to order from the parts guy who has no clue, here is the number
Dorman 13935
7/16 x 20
