Old 11-19-2015, 09:22 PM   #1
SoCoC10
SoCoC10's Avatar
Help! Upper and lower ball joints are too far in new drop spindles?
I installed some 3" drop spindles on my 69 GMC and the outer tie rod fits fine but the upper and lower ball joints are sitting way too deep in the spindle? The castle nut is 5-8 threads past the cotter pin hole. My guess is the previous owner used 71-72 spindles to do the disc brake swap so I need 71-72 drop spindles? Thanks for the help.
Here is a casting # off the stock height spindles I just removed.
07' Extcab Silverado Z71 Silver Birch, 5.3L HO
71' Cheyenne C10 Hugger Orange on Saddle SWB
Besides these two, too Many to count
SoCoC10 is offline   Reply With Quote
Old 11-19-2015, 10:05 PM   #2
SoCoC10
SoCoC10's Avatar
Re: Help! Upper and lower ball joints are too far in new drop spindles?
I'm leaning towards 71-72 because the lower control arms do not have rubber bushings. See pic.
Old 11-19-2015, 10:09 PM   #3
SoCoC10
SoCoC10's Avatar
Pic of castle nuts too far away from cotter pin holes.
Old 11-20-2015, 07:45 AM   #4
PGSigns
PGSigns's Avatar
Yup those are 73 and up spindles with 72 and down ball joints. Can swap the ball joints to correct it. Also double check the fit on the tie rods just in case.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 11-20-2015, 10:01 AM   #5
SoCoC10
SoCoC10's Avatar
Tie Rod fits perfect. That is what is confusing me. The upper and lower ball joint are brand new done by the previous owner. I would much rather install the correct spindle for the already done ball joints than change the ball joints to match the incorrect spindle. So i should install a 71-72 spindle?
Old 11-20-2015, 11:29 AM   #6
chevy_mike
Never Ending Projects
chevy_mike's Avatar
There are three different spindle year split, 63-70, 71-72 and 73-87. You need to know what ball joints you have to know what spindles you need.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-20-2015, 12:27 PM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
X2
How did you buy a spindle without knowing what it fit?
Your outer tie rod may look correct,... But it has to match the year of spindle also,...
Keith
Convert to disc brakes.
Old 12-06-2015, 09:38 AM   #8
SoCoC10
SoCoC10's Avatar
Thanks for all the input. I ended up with 71-72 drop spindles and it corrected the problem. I think you would all agree that since the truck had brand new upper and lower ball joints it was much easier to unbolt and bolt in the correct spindle than unbolt and press different ball joints.
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help.
