Old 11-27-2015, 07:29 PM   #1
BCOWANWHEELS
70 c-10 drum brake wheel cylinder r&r
I,ve never worked on drum front brakes on these old trucks so I need a little tutoring please. I,ve got the hub/drum off,all brake shoe hardware off , brake line loose from hard line and "c" clip off and I,d like to install new front wheel cylinders on both sides. do I have to remove the backing plate to get to the back bolts or what ? if so while I have them off I,am going to sand blast my backing plates and paint em while there off. lastly can I swap over to the 2 1/2" brake shoes and matching drums while I,am in there ? I have standard duty brakes now.
thanks
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 11-28-2015, 09:19 PM   #2
BCOWANWHEELS
Re: 70 c-10 drum brake wheel cylinder r&r
well got in deep today on my front brakes, to remove the wheel cylinder you have to remove the backing plate, theres 2 long bolts at the center bottom that need to come out and the big brake shoe center pivot bolt at the top has to come out. its 1 1/8" deep well socket to remove I highly suggest 6 point and 2 ft breaker bar. there is a locking bend over tab that needs to have to tab bent down before socket will fit on pivot bolt. this is a safety measure I bet. the rubber line can stay on until you get backing plate off as wheel cylinder will come out with line attached once backing plate is off. since your replacing the wheel cylinder go ahead and replace the rubber line also, there 10.00 each at oriellys. you,ll need a deep well 3/4 for outside backing plate and shallow well for inside lower bolts. it helps to turn steering right,remove 1 bolt then left to remove 2nd bolt as it gives you more room on the backside for socket clearance . now off to sand blaster with drums and backing plates . more to come . its not that bad of job so don't fret it.
Old 11-28-2015, 10:21 PM   #3
Boog
laying low
Boog's Avatar
Some times you just have to dive in there and make your own way, eh Bob?
Really we all should have a factory service manual for things like this.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-28-2015, 10:24 PM   #4
BCOWANWHEELS
yea, I can see why gm left drum front brakes if this was there best shot at it. I wasn't impressed with the design from the start. and getting to the adjuster from the drum side ????????????? never in my days have I seen such a poor design.
Old 01-19-2018, 06:41 PM   #5
mikes c10
Thanks for this post from a couple years ago , just followed your lead , you were spot on ! Tks ! My 1970 C10 longbed got a little closer to rolling again ! Mike
mikes c10 is offline   Reply With Quote
Old 01-19-2018, 08:06 PM   #6
demian5
demian5's Avatar
Yeah this is good, most GM front drum brakes from 60s and 70s are like this.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 01-20-2018, 02:11 PM   #7
yuccales
yuccales's Avatar
Mike, welcome to the site. Tons of great info here. Don't forget to post some pics of your rig!
yuccales is offline   Reply With Quote
Old 01-21-2018, 08:20 AM   #8
mikes c10
Thanks Yuccales ,
Always wanted an old beater truck , so went out and found a 1970 C10 fleetside longbed. Its a bucket of rust held together with bondo , but i think i can bring it back to life. I`m not a "truck" guy , so im learning as i go.
Digging in to the brakes now , replacing drums ,shoes ,wheel cylinders and all hardware. I think im headed to the "ratrod" look , kinda cool looking but definitly not a true restoration. Anyway , all new to me ,but its fun.
Heres a few pics. ( took a 12 ton puller to get those back drums off ! )
Old 01-21-2018, 11:19 AM   #9
yuccales
yuccales's Avatar
Don't look to bad for an "old beater truck". They are fun to work on, and you will never again say "I have nothing to do today!"
