12-27-2015, 09:34 AM | #1 |
Factory tach to HEI with external coil info needed
The engine in my 67 is a 350 TBI out of 1990 1500 truck. The HEI distributor has a "external coil". Anyone know what wire to tap into for tach signal? Any info would help.
Thanks. |
12-27-2015, 10:22 AM | #2 |
Re: Factory tach to HEI with external coil info needed
It will need to go to the NEG side of the coil
12-27-2015, 10:51 AM | #3 |
white wire if I recall correctly, the pink is hot.....
Ben |
12-27-2015, 11:03 AM | #4 |
Snipe is correct it is white and there should be a spade type hook up just off of the coil that your wire will/could plug into. The plug has a funky looking cover on it but that is where you want to be. They made that i suppose for the one for tach to not have to splice into the wiring.
12-27-2015, 12:24 PM | #5 |
Found white plug. Hook up brown wire to white and pink to ign power. Right?
12-27-2015, 12:30 PM | #6 |
Yep!
That's it..... Ben |
12-27-2015, 12:45 PM | #7 |
Hooked ground to tach and hooked up wires like last post. SUCCESS.!!!
Thanks guys for the help! |
12-27-2015, 12:49 PM | #8 |
That's what this board is all about! Sometimes it's instant answers, sometimes it takes a while, but lots of folks willing to help!
Have a great day! Ben Smith |
