Old 12-28-2015, 01:28 AM   #1
jadedbird
jadedbird's Avatar
panhard bar with a watts link ?
if I run a watts link will I need a panhard bar ( or panhard rod or track bar or whatever you call it)
I plan on running bags in Stock locations (2500s all around) with a bolt in notch and 2" lowering blocks, flipped trailing arm brackets and shock relocators and raised bed
not looking to be laying frame just going to lower the altitude
jadedbird is offline   Reply With Quote
Old 12-28-2015, 02:29 AM   #2
tinydb84
tinydb84's Avatar
Re: panhard bar with a watts link ?
You need one or the other but not both.
David
Instagram: myfabguy
Old 12-28-2015, 03:12 AM   #3
andrewmp6
Yeah like said you need one they both do the same job,But to me the watts link does the job a little better then a panhard bar.
andrewmp6 is offline   Reply With Quote
Old 12-28-2015, 01:00 PM   #4
jadedbird
jadedbird's Avatar
alright cool. I was checking out instagram builds and several people has used both I thought it was over kill myself
Old 12-28-2015, 01:24 PM   #5
tinydb84
tinydb84's Avatar
Can you post a picture of them? I would imagine it would bind as the Panhard bar forces the axle to move laterally but the Watts wouldn't allow the same amount of movement. Plus packaging all that together would be interesting.
David
Instagram: myfabguy
Old 01-01-2016, 04:30 AM   #6
andrewmp6
I can't see anyone running both because one would end up binding and maybe breaking.
