Old 12-29-2015, 09:42 PM   #1
6768chevylover
6768chevylover's Avatar
brake assist
i have disc brakes all around my blazer and was wondering how much a difference brake assist would make over original power brakes?
6768chevylover is offline   Reply With Quote
Old 12-30-2015, 10:08 AM   #2
LS short box
Re: brake assist
If you are talking hydro boost they are great. They run off the power steering pump. You don't have to worry about engine vacuum if you have a bigger cam.
LS short box is offline   Reply With Quote
Old 12-30-2015, 10:29 AM   #3
6768chevylover
Re: brake assist
Is that the only advantage? I would think having greater pressure just locks up the brakes quicker for our non-anti-lock brakes..
Old 12-30-2015, 03:13 PM   #4
LS short box
Re: brake assist
You can certainly lock them up with a hydro boost. Had a hydro boost on a 67 Nova and a 66 Mustang. Took a little getting used to but much nicer than a under vacuum assisted power brakes.
Having said that my other 67 Nova had a wildwood manual system 7/8 or 1 bore MC I forget with C5 Corvette brakes all around and that stopped very nicely. Had to push a bit but never felt like it wouldn't stop as needed.
Old 12-31-2015, 11:47 AM   #5
New_70'C10
New_70'C10's Avatar
Re: brake assist
That's a great question as I'm going with disc all around and was looking into a hydro boost set up. I know they make a kit for it but which route are you looking at taking, kit or retrofit?
1970 SWB CST; 307ci, 200-4R, (Slow Motion)
New_70'C10 is offline   Reply With Quote
Old 01-01-2016, 12:07 AM   #6
drfloyd
Re: brake assist
So, are the same calipers used on a hydro boost system that are used on a manual system?
drfloyd is offline   Reply With Quote
Old 01-01-2016, 12:57 AM   #7
andrewmp6
Re: brake assist
Yeah the calipers are the same no matter if you run manual brakes or any forum of power brakes.Have you guys looked at http://www.abspowerbrake.com/ they have a electric system they makes its own vacuum with out running any kinda booster.
andrewmp6 is offline   Reply With Quote
