Old 12-29-2015, 10:14 PM   #1
adammellick
Rear end question
I found a 12 BOLT 6 LUG REAR END--NON POSI 3.73 GEAR--coil spring out of heavy 1/2 ton truck. Will this bolt into my 67 3/4 ton? Can I just swap the axles to 5 on 5 pattern?
adammellick is offline   Reply With Quote
Old 12-29-2015, 10:17 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rear end question
You need to get the proper length axle shafts. Stock 71-72 5 lug axle shafts will be too long.
I am using a 1969 12 bolt in my 1972 and bought shorter conversion shafts with 5 lugs from Moser.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 12-29-2015, 10:25 PM   #3
adammellick
That is good info. My main concern is that it will fit in the truck. I want to jump on this thing for $110 & he is only 5 miles away. I will make sure I measure the axles before I buy the new ones. Thanks for the help.
Old 12-29-2015, 11:02 PM   #4
hugger6933
If your truck is coil sprung and the rear is for coil springs then the answer is yes it will bolt in/under your truck. Jim
hugger6933 is offline   Reply With Quote
Old 12-30-2015, 10:22 AM   #5
Mike C
Mike C's Avatar
But you cannot swap the 1/2 ton axles into a 3/4 ton housing. They mount completely different
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-31-2015, 11:42 AM   #6
volksworld
if the 6 lug rear you found is out of a 70, the stock 5 lug axles will fit...but the earlier rears are too narrow for stock axles...but plenty of places make them
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
