Old 12-30-2015, 11:13 PM   #1
jaybatta
jaybatta's Avatar
convert 67 C30 to K30?
I have a 68 K20. I want to buy a very nice looking 67 C30 and convert to 4wd. I want to use the parts from the 68 and keep the 1 ton suspension. I feel like this is a foolish question, did they ever make a K30 dually? I'm wondering what would be easier, move the body onto the K20 frame and swap the suspension, or ......swap the front axle, install the xfer case and crossmember, cut a hole in the floor
Thanks,
Joe
Joe
1968 K20
1970 K20
Semper Fi
jaybatta is offline   Reply With Quote
Old 12-30-2015, 11:17 PM   #2
hugger6933
Re: convert 67 C30 to K30?
I don't think there was a dually one ton until the square trucks sometime after 74-5 ish. Jim
hugger6933 is offline   Reply With Quote
Old 12-30-2015, 11:27 PM   #3
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
The frame would be more stout under the c30. It is less work to stick axles under the 68 4x4 frame, but the frame isn't as strong. Especially if you are planning on a diesel.
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 12-30-2015, 11:37 PM   #4
jaybatta
jaybatta's Avatar
That's the direction I was leaning towards. How hard would it be to throw a transfer case under a 2wd? Is there room for a cross member on a 2wd frame?
Joe
1968 K20
1970 K20
Semper Fi
Old 12-31-2015, 12:08 AM   #5
71blksuper4x4
SWB 4x4 Collector
Yes there is as they are the same width until the bed area. On a 4x4, the frame stays straight all the way back from the front cab supports all the way to the rear. 2wd rear sections change widths. For the front suspension, you can swap components from the 68 over to the 67. I took a C30 c&c frame and converted it to 4x4 for my crew cab build.
TREVOR
Old 12-31-2015, 12:15 AM   #6
jaybatta
jaybatta's Avatar
Whats a c&c frame? I don't suppose you have pictures of the frames you used or maybe have a build thread? Ahh I think I see it, the 72 Cheyenne super?
Joe
1968 K20
1970 K20
Semper Fi
Old 12-31-2015, 12:20 AM   #7
57taskforce
All about them K’s
57taskforce's Avatar
Cab&Chassis. No 1ton 4x4s of any kind in the 67-72 years. The k/20 was king of the castle in the 4x4 trucks.
Tyler
57taskforce is offline   Reply With Quote
Old 12-31-2015, 09:06 AM   #8
68panelman
68panelman's Avatar
Any K30 would of been a Napco conversion. There's pictures somewhere on the forum.
68panelman is offline   Reply With Quote
Old 12-31-2015, 10:09 AM   #9
CrewCab59
CrewCab59's Avatar
The factory gm k30 started in 1977. The rest info can be found here.
http://67-72chevytrucks.com/vboard/s...d.php?t=657893
1972 Custom Deluxe 20 4x4 burb
1971 GMC SWB CST 4x4
1972 GMC k20 4x4 (X- brush truck )
1971 Chevy CST Blazer 4x4
1971 Chevy C/10
1970 Cab Chassis C30 157"
1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica )
1988 Chevy V30 4x4 wrecker challenger 4812
CrewCab59 is offline   Reply With Quote
