02-21-2016, 07:07 PM | #1 |
fuel cell access through bed
For those of you with fuel cells mounted UNDER the bed between the frame rails , what are you using for access to fill er up!!
I don't want to just cut a rectangular hole in the bed and attach some hinges and it look messed up Is there a plate I can purchase to weld into the bed floor? Something preferably locking to prevent fools from messing with my tank |
02-21-2016, 11:00 PM | #2 |
Re: fuel cell access through bed
following
1983 Scottsdale K10 496 /t400 fmvb /208 /D60 and 14ff with Locker /35x12.5x15 mt baja mtz 680hp/720ftlbs of NA fun |
02-22-2016, 08:20 AM | #3 |
can use something like this http://www.jerrybickel.com/fuel-syst...ace-mount.html or http://www.speedwaymotors.com/Chrome...Fill,5854.html
02-22-2016, 09:13 AM | #4 |
02-22-2016, 02:06 PM | #5 |
yeller
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
02-23-2016, 11:56 AM | #6 |
02-24-2016, 12:53 AM | #7 |
Jeff I actually used your thread you linked and sent it to some fab shops to get a quote on fabrications is there anyway you can tell me exact dimensions?? I know the ring is 1/2" with 1/4" recess
02-24-2016, 12:54 AM | #8 |
02-24-2016, 01:27 AM | #9 | |
Here's a locking version of the door: http://www.summitracing.com/parts/asm-6058kl/overview/ |
02-24-2016, 01:52 AM | #10 |
So it looks like there is a plate that was welded and the door mounted to the plate. Then work around the factory ribs.
Thank you for the link as well. I like the look of that a little better |
02-24-2016, 01:13 PM | #11 |
The work done to the bed floor is what makes that look so nice. cutting a hole and mounting the door is a no brainer. very nice work.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
02-24-2016, 07:20 PM | #12 |
I'd like to do a blazer or suburban tank on my C20 and then run the filler forward to the door in my utility bed just behind the wheel well. Anyone do this? Or I could put the filler in one of the boxes I guess but that might be awkward.
1973 C20, 350/350 |
02-24-2016, 11:27 PM | #13 |
02-25-2016, 04:07 AM | #14 |
That's awesome Haulin!!
02-25-2016, 10:21 AM | #15 |
Frequent Flyer
Might look at these as well. They aren't as easy for anyone just walking by to open.
I have one in my 76. http://www.ridetech.com/store/coolca...l-gas-cap.html |
02-25-2016, 01:17 PM | #16 |
yeller
I no longer have the truck or information on the ring, sorry.
