Old 02-24-2016, 07:32 PM   #1
murguia
HELP! With Rear sliding window parts
Hey fellas, I just picked up an amazing all original paint 77 GMC but the rear sliding window is missing the middle latch as well as the two aluminum pieces that line the center when closed for the latch to connect to. Any idea if they sell these separately, or if you have the pieces I need for sale, I'll gladly buy them
Nick
murguia is offline   Reply With Quote
Old 02-24-2016, 07:47 PM   #2
Pontiac1976
Pontiac1976's Avatar
Re: HELP! With Rear sliding window parts
Try a Glass Window shop to see if they have the parts. Or your going to have to check the scrap yards.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
