Old 02-28-2016, 03:28 PM   #1
Thanos
Thanos's Avatar
14 bolt dually diff ,04 has no front pinion bearing
I assumed all Corp 14 ff had the "pilot" bearing on the front of the pinion gear however I just looked at one 15 mins ago that did not. Do some not have that or there different ff 14 bolt difs?
Thanos is offline   Reply With Quote
Old 02-28-2016, 03:31 PM   #2
Bigdav160
Bigdav160's Avatar
Re: 14 bolt dually diff ,04 has no front pinion bearing
I don't think the 9 /2" gear did. All the 10 1/2" geared units I've taken apart have had the pilot.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 02-28-2016, 03:35 PM   #3
Thanos
Thanos's Avatar
This is a 1 ton dually 04 it should have it,it has a huge ring gear in it. It even has the disc brakes and ff axles... I don't understand this mystery
Old 02-28-2016, 04:37 PM   #4
57taskforce
All about them K’s
57taskforce's Avatar
Negatory. The newer 14 bolts went to an 11.5 gear and lost the pinion support bearing. (I assume the pinion support is what your talking about. They changed somewhere around 01. The strength between the 10.5 and 11.5 14 bolts is supposed be about the same.
Tyler
57taskforce is offline   Reply With Quote
Old 02-28-2016, 05:07 PM   #5
Thanos
Thanos's Avatar
I just got a AAM 11.5 for 200.00 out of an 04 60k miles!
Old 02-28-2016, 09:13 PM   #6
Thanos
Thanos's Avatar
Yes! I learned this today, the one I found is a short WMS so it also measured 42 1/2 so my 72 will drop right on the perches. Disc brakes,373 gears and the center dif is HUGE.
So I guess this will work well for my dually conversion.
Old 02-29-2016, 09:44 AM   #7
Mike C
Mike C's Avatar
You've gotten good info from the other guys. The 11.5 Aam axle does not have the bolt on pinion support as you have seen. It is not a FF 14 with the 10.5" ring gear and removeable pinion support.
More info on dually rears: Most square body dually' swerve Dana 70 HD. The cab and chassis trucks usually had the FF 14 as the installed diff. I have both an 86 K30 with the 70HD and an 85 CnC with the FF 14. It's amazing how much wider the 70 is as well.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 02-29-2016, 10:12 AM   #8
Thanos
Thanos's Avatar
Yea the original one I bought to replace the dana 60 is a 70 hd and its like 76' WMS so I'm stuck with a extra dif atm, the AAM is much shorter I think we measured 68 ish so that tucks the outer dually wheel in better.
I read the AAM is stronger than even a 80 however we all know people argue over whats better than what. I will say I can beat the disc brakes,11.5 gear,373's and shorter WMS it seems a better dif for my project anyway.
