03-03-2016, 11:56 PM | #1 |
Anyone restore A/C Duct Air ("diverter box") flappers?
Nice work at a reasonable price and I know someone interested. Hopefully I'm not breaking any board rules here.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-04-2016, 04:10 AM | #2 |
Re: Anyone restore A/C Duct Air ("diverter box") flappers?
I consider that a throw away item once the flapper door breaks. Sucks because they aren't exactly cheap either. With it being made out of plastic, and the way the whole diverter box is constructed (and also being made out of plastic), there isn't much that can be done. Although I have seen some attempts at fixing the door with wood, sheet metal, and glue. I have only "restored" those that have a good flapper door
03-04-2016, 08:01 AM | #3 |
Active Member
I just bumped up an old thread where I showed how to make a permanent repair to the flapper. saves a ton of money and keeps your truck original. Look under "air regulator question".
72 Sierra Grande 2500 BB 72 Sierra 2500, 42K miles, factory buckets 72 Cheyenne 20 72 Chevy SWB, Factory BB, Leaf Spring |
03-04-2016, 10:16 AM | #4 |
Just looked at your pics. That's the cleanest way I've seen it done. Great way to save a nice chunk of change.
03-04-2016, 03:51 PM | #5 | |
Thank you! Mike. |
03-04-2016, 06:30 PM | #6 |
Observation: I've seen a few NOS diverter boxes and they all have one thing in common, which is the pin on the lever is more narrow than the original from my truck. Really, the entire lever isn't built quite as well.
Don't know if any of you guys have experienced problems, and would be interesting to hear, but I do know of one member whose pin broke when he tried to attach the cable wire.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-05-2016 at 01:45 AM. |
03-04-2016, 06:46 PM | #7 |
I've noticed the same thing.
03-05-2016, 01:33 AM | #8 | |
If it matters, the rubber around my hinge is wasted. I can spin the lever and it doesn't lock, which brings me to my next question. If it's handy, which direction should the pin side of the lever face, and the position of the flapper, when you lock it down? I think I know, but confirmation would be great. Here's your thread. Thanks Pappa: http://67-72chevytrucks.com/vboard/s...d.php?t=338890
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-05-2016 at 01:49 AM. |
03-05-2016, 11:02 AM | #9 | |
Once you put it on the flapper shaft the tension of the strap held by the screws makes it very tight! The angle of the lever when in the a/c "on" position(switch closed) will have the flapper all the way closed. I had to screw the cable clamp a few turns to fine tune mine so that the flapper worked full distance both ways with the control. Mike. |
03-05-2016, 09:46 PM | #10 |
I see. Didn't notice the plastic before, or what's left of it. I don't have a welder, but I may be able to come up with something. Thanks for the info.
03-06-2016, 12:44 AM | #11 |
I did mine by copying what I got from here on the site.
The metal strap I used is a common rafter tie or what we call a hurricane strap. Look here for the post-- http://67-72chevytrucks.com/vboard/s...d.php?t=338890 Scroll down and he shows it in great detail and very easy to do! Mike./ |
