Old 07-05-2016, 09:26 PM   #1
Robznob11
Robznob11's Avatar
67-72 custom LED cargo/brake light combos
you asked for them here they are... choose what you want 47$ shipped to your door. these are made to order, so give me a week
https://youtu.be/Ze59QfHST9M
https://youtu.be/QjaN22WEsfs
https://youtu.be/1E4SZs9NnrE
https://youtu.be/h_j3y15Xsxw
hope you like them... PM me if interested!!!
These are not plug and play they will require you to tie them into your brake light (before the tail so you wont get a blinker function: LOL!)
Also If you would prefer to have all red or all white (very bright) I will make them at the same cost.... just let me know!
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 07-06-2016, 10:27 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: 67-72 custom LED cargo/brake light combos
PM sent.
Hart_Rod is offline   Reply With Quote
Old 07-06-2016, 10:30 AM   #3
Robznob11
Robznob11's Avatar
I will get it out first thing in the morning! Thank you sir!
LED TAILS
Old 07-06-2016, 02:55 PM   #4
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I really like what you have done. I am not that good with wiring so I have to ask, do you need to run a wire from the cargo light through the roof, rocker etc to under the dash to hook into the brake light wire?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-06-2016, 02:56 PM   #5
Robznob11
Robznob11's Avatar
Wink Re: 67-72 custom LED cargo/brake light combos
I did not mention it in the video but on the bowtie version you dont have to run it as a running light. It is on a separate wire that can be used if you want. I can put a running light function on any. But i always liked the off then on for brake. I put that option on that on for the person who wants to be creative with their lense and have a bowtie glowing at night. Also if a person wants white only it should be very bright with a total of 36 leds on the board.
LED TAILS
Old 07-06-2016, 03:00 PM   #6
Robznob11
Robznob11's Avatar
Im pretty sure that is accurate. I build these but I dont run one however. Lol. My truck is more hot rod. Maybe someone who has converted theirs will chime in. It can not tie into the tail wire because then it would blink😏
LED TAILS
Old 07-06-2016, 03:09 PM   #7
Robznob11
Robznob11's Avatar
After a little reserch I found you can run the wire to the switch on the break pedal😉 . Also for those with no light at all who want the stock set up. I have a copy of the original gm instructions for mounting one on the truck. It even tells where to drill the holes and measurements. We have good board members here who have helped me with this info!!!!
LED TAILS
Old 07-06-2016, 04:06 PM   #8
74baggedbug
Nice!!! To bad I don't have a cargo light .. Ever thought about making a dome light for inside the cab?
74baggedbug is offline   Reply With Quote
Old 07-06-2016, 04:09 PM   #9
Robznob11
Robznob11's Avatar
I can do a dome. Again i just need a pattern lol. I dont run much of anything stock on my truck . I even have a 61 dash lol
LED TAILS
Old 07-06-2016, 10:50 PM   #10
Robznob11
Robznob11's Avatar
Here are some pics. I took the lighted ones in my laundry room with everything pitch black so you can get an idea of the light output.
LED TAILS
Old 07-07-2016, 01:08 AM   #11
PapaNui
PapaNui's Avatar
PM sent.
PapaNui is offline   Reply With Quote
Old 07-07-2016, 09:07 AM   #12
Hart_Rod
Hart_Rod's Avatar
Sweet! Can't wait to get mine.
Old 07-07-2016, 05:25 PM   #13
First c10
First c10's Avatar
Hey Rob I will take a full set like I PM'ed you about.
please send PayPal info
thanks
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 07-07-2016, 05:26 PM   #14
Robznob11
Robznob11's Avatar
Yes sir, i will get started on the tails it may take a week to get them all done. I assume you want the standard version cargo?
LED TAILS
Old 07-07-2016, 09:49 PM   #15
74baggedbug
Would I need to send you mine? Lmk and we can set something up.. Thanks
Old 07-07-2016, 09:58 PM   #16
Robznob11
Robznob11's Avatar
That would work . Are you looking for something to plug in or can you hook up the wires?
LED TAILS
Old 07-08-2016, 09:23 AM   #17
First c10
First c10's Avatar
Not sure the difference between standard 1 or 2.
cargo light, 3rd brake light,Is what I want.
GO GO!!!
Old 10-18-2016, 10:57 AM   #18
Hart_Rod
Hart_Rod's Avatar
bump
Old 10-18-2016, 11:20 AM   #19
kehstr
kehstr's Avatar
How did you wire the cargo light up to the factory wiring?
72 GMC highlander nicknamed by my then 6-year-old brother "stripes"
http://67-72chevytrucks.com/vboard/s....php?p=7378180
Check out my Youtube channel
@Chad's Fab
kehstr is offline   Reply With Quote
Old 11-18-2016, 12:37 PM   #20
First c10
First c10's Avatar
You will need to run a wire up to the cargo light for the 3rd brake light.
of course this is only if you already have a cargo light installed.
if no cargo light at all you will need a brake wire and a power wire for the cargo light.
I installed as 3 way switch under the inside dome light that will allow the cargo light to be on when you open the door or can be switched on or off manually.
Hope this helps
And a BUMP for Rob!!
GO GO!!!
Old 11-18-2016, 02:37 PM   #21
Twisted78SS
Wide n'Low
Twisted78SS's Avatar
pm sent
Trippin Hazard.. 67 swb,
Gold Member.. 68 Suburban
Air Force Retired
Twisted78SS is offline   Reply With Quote
Old 02-14-2017, 10:32 AM   #22
Robznob11
Robznob11's Avatar
Here is a combo that first c10 got. Its the max coverage you can fit.
LED TAILS
Old 02-15-2017, 11:37 AM   #23
Theboatandcarman
looking good! plan on ordering after i get out of paint!
keep on building. http://67-72chevytrucks.com/vboard/s...d.php?t=680094
2017 GMC Canyon diesel
1968 Chevrolet C20
1970 Mercedes 280S
(WTB 1968 4wd barn door suburban)
Theboatandcarman is offline   Reply With Quote
Old 11-16-2017, 03:33 PM   #24
indymachinist
Super old bump. Are you still doing these? Anyone got any installed pictures?
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 11-16-2017, 03:42 PM   #25
Hart_Rod
Hart_Rod's Avatar
Mine works great! I think there are pictures in my suburban build thread.
