08-12-2016, 10:12 PM | #1 |
Entropy LSX Radiator with dual fans
My brain is tired, need some help.
So I have installed a radiator from Entropy, their LSX version with dual fans and two speed controller. Original ECM thermostat is in the drivers side of the block, Dakota Digital Temp unit is in the passenger side of the block. The radiator came with another thermostat with absolutely no markings. If I splice the fan controller temperature units wiring into the ECM unit the truck will not start. I have not tried to splice it into the Dakota Digital Temp unit yet. Any ideas of how to make this work? Sorry if I have confused you more than I am already.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
08-13-2016, 10:52 PM | #2 |
Re: Entropy LSX Radiator with dual fans
Why not let the computer control the fans? Or use a temperature switch in the radiator?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
08-13-2016, 11:01 PM | #3 |
Post Whore
Same as hartrod said ..I've got dual fans and dual relays..each fan has its own relay that are run by the ecm..each fan is set to come on at a different temp
08-14-2016, 01:18 AM | #4 |
ECM only has 1 fan circuit, I want to use the controller because of the two speed control and staggered start of the fans.
Removed the Dakota Gauge temp sending unit and installed one for the fans. Will use ECM to feed temp to Gauges in Dash.
08-14-2016, 08:35 AM | #5 |
Why not put the Fan temp sender in the radiator?
08-15-2016, 03:12 PM | #6 |
That's a possibility but with the heat this thing runs I would prefer in to be in the block.
