08-16-2016, 06:01 PM | #1 |
modifying a stock harness
2003 yukon 5.3 2wd dbw
i cut off the plug for the fusebox and i labeled all the pink wires per the instructions on lt1swap.com problem is the only pink injector wires labeled are the #2 and 4 which is E5 which pinks are the other fuel injectors?
1967custom Last edited by michael bustamante; 08-16-2016 at 06:10 PM. |
08-16-2016, 10:44 PM | #2 |
Re: modifying a stock harness
I don't have a schematic in front of me, but you should be able to trace the wires back to the injectors. At least that's what I do. I like the assurance that the schematics I read are indeed correct. I've seen a few mistakes of stuff listed on the Internet. Good luck
08-17-2016, 08:36 AM | #3 |
get out your multimeter it would probably be quicker than trying to trace it down with a diagram and more accurate
08-17-2016, 09:50 AM | #4 |
^^^^thats how I did it
65Gregg Blue long bed White TBSS 61 Impala “The two most important days in your life are the day you are born and the day you find out why.” Mark Twain |
08-17-2016, 10:02 AM | #5 |
Not sure how you could have labeled all the pink wires and only had two injector wires, there should be eight of them, they each have their own power wire in a truck harness. You can tie them together if you want. I usually tie all four lefts and all four rights together and have two fuses.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
08-17-2016, 11:08 AM | #6 |
yeah thatas what i was wondering too but if you look at the pinout diagram on lt1 swap it only lists 1 prong as 2 and 4. i was just hoping that you guys would know which other prongs are the injectors as the harness is off the engine and not in veh. (in my lliving room)
and i dont know which injector plug is which and not how how to apply poer to id wire so ill have to trace them
1967custom |
