Old 08-20-2016, 11:22 AM   #1
pete57
??? about my 5.3 engine
started my ls swap in my '64 and need to know what this line is for. It was ran together with the fuel line in the original truck. Its a 2005 engine and i thought that after 2003 they went to a returnless fuel system.?. Need some help before i start running fuel lines. Thanks..
pete57 is offline   Reply With Quote
Old 08-20-2016, 11:46 AM   #2
lowrodderchev
lowrodderchev's Avatar
Re: ??? about my 5.3 engine
Its a return line I thought the same thing but i buddy who's intake has one to. Does yours have the DBW or DBC?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 08-20-2016, 11:57 AM   #3
homemade87
That hose on the top front of the intake is not a return line . It is a purge valve for the gas tank pressure . It is not needed at all . Just take the hose off and leave the purge valve in for a plug . All you will need to do on that 2005 engine is to use the corvette filter down on the frame rail that does have a return on it . Then run a single line up to the fuel line on the intake .
homemade87 is offline   Reply With Quote
Old 08-20-2016, 01:32 PM   #4
pete57
It has the DBW.
Old 08-20-2016, 01:36 PM   #5
pete57
Cool, thanks. That will save me some time and trouble running a 2nd line.
