Old 08-25-2016, 05:09 PM   #1
tommy217xxx
tommy217xxx's Avatar
What is this
I've got an 80 with a 305 and I noticed this. What is it?
TJ
76 gmc 1500 swb patina finish
Dropped 4/5, 350/4 speed
80 Chevy c10 lwb
305/350
tommy217xxx is offline   Reply With Quote
Old 08-25-2016, 07:50 PM   #2
83GMCK2500
Re: What is this
Vacuum actuator for the heat riser valve located between manifold and exhaust pipe.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 08-26-2016, 04:59 PM   #3
tommy217xxx
Re: What is this
It looks like it's all one assembly that has 4 plus on it. Does anyone have a part number or know what the part is called?
TJ
80 Chevy c10 lwb
305/350
Old 08-26-2016, 06:40 PM   #4
tommy217xxx
Re: What is this
This is what the other end looks like.
TJ
80 Chevy c10 lwb
305/350
Old 08-26-2016, 08:09 PM   #5
Jake Wade
Jake Wade's Avatar
Re: What is this
Looks like smog crap
Jake Wade is offline   Reply With Quote
Old 08-27-2016, 07:51 AM   #6
D13
D13's Avatar
Re: What is this
As noted above, it is the vacuum actuator for the heat riser. When the engine is cold, it uses exhaust heat to help the engine warm quicker, improving cold driveability and yes, reducing cold emissions. The tubing is part of the vacuum control system that goes to a Thermal Vacuum Switch (TVS) that looks at the engine temp to turn the actuator on or off. One line vacuum to the switch, the others are to devices to be turned on or off.
If you do remove the actuator make sure to wire the valve in the open position.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 08-27-2016, 11:18 AM   #7
tommy217xxx
Re: What is this
Ok. We're getting closer. Is it possible to replace the tubing or do I need to replace the entire plug. Is there a name or part number for the thermal vacuum
Switch plug.
TJ
80 Chevy c10 lwb
305/350
Old 08-29-2016, 11:10 AM   #8
83GMCK2500
Re: What is this
Vacuum tubing should be available over the counter at any auto parts store, just need to size it correctly. Vacuum tubing can be sized in increments of 32nds of an inch, I'd just make sure it fit snug and didn't leak. I've always maintained this portion of my '83 and I find that it runs well and performs well from cold-hot.
I'd be surprised if there was an original/NOS one of those vacuum tubing harnesses laying on a shelf somewhere, but I suppose it is possible. If you want to find on I would suggest, looking for a user on here named "Hatzie" he's got a link in his signature to many .PDFs including the original parts catalogs. You can use them to find the part number and then go hunting.
Devin
New Daily, the '96
