Old 08-30-2016, 11:36 AM   #1
suburban99
suburban99's Avatar
205 transfer case to 4L80E?
Will be starting a 6.0 & transmission swap on my 72 K10 soon. I have a 4L80E and transfer case that came with the donor (2002 silverado HD) but the tranny is shot. I am wondering if I should do a 700R4 instead? K10 has a 205 transfer case. Whats your thoughts? Turbo 350 in truck has low miles on a rebuild and shifts good.
1962 C10 Longbox LS 5.3 4L60E----Sold$$
2014 Ram 4x4 3500 Laramie Diesel..Momma's truck
2015 Ram 4x4 1500
1997 Boxster.
1972 K10 Custom Deluxe LS 6.0
1950 GMC 3100 S10 & LS swapped
suburban99 is offline   Reply With Quote
Old 09-04-2016, 08:49 PM   #2
wildwilly4x4
Re: 205 transfer case to 4L80E?
Do some searching and you will find the answer your after, as its covered fairly often. You have the wrong tcase for a 4l80 swap, but it can be modded to fit. This will require the input bearing bore to be enlarged and a 32 spline input gear. Then you will need to buy an aftermarket adapter. There is possibly and adapter to mate the 80e shaft to your 205, but if there is, Im not familiar with it. To mate is to the 700r4 or 4l60e wont be a huge problem, but you will still need a few aftermarket pieces to set it up.
wildwilly4x4 is offline   Reply With Quote
