Old 09-04-2016, 05:05 PM   #1
Sean1985
Sean1985's Avatar
Ls3 idle and possible exhaust leak
I just finished up a ls3 525hp and a tremec swap in my 67. I probably put about 100 miles on it with no issues. Changed the oil once and it looked great.
A couple days ago I started to hear a light tick and really thought nothing of it. I got on it a little to about 4500rpm in 2nd gear and it got worse. I immediately thought it was a exhaust leak so I swapped the headers gaskets and tightened down the collectors. Still the same.
I found the Evap line was rubbing the idler pulley and it wore a hole in it. So i capped that off and the same thing. The rpm is a little spiratic. Sometimes is stays at 2000 rpm when I start up or if I rev it a little.
At this point I'm a little stumped. No check engine light and I don't have a tool to plug into. Not sure if I need the Evap. The harness does not have a plug for it. Any help would be great. Thanks.
Sean1985 is offline   Reply With Quote
Old 09-06-2016, 02:04 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Ls3 idle and possible exhaust leak
Not saying this is your case, but in a previous swap I had an oil pump o-ring go bad and was causing ticking. Got worse as the oil warmed up.
Was this engine a pull out? Using the factory LS3 exhaust manifolds? It's possible they could have been cracked in the wreck.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 09-06-2016, 07:41 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Put a screwdriver on the valvecover and tell me if you can feel the tick through it. (older guys should understand what I mean by this).
If its valvetrain noise or lifter tick, you can usually feel the mechanical *tick*in the vibrations of the motor.
If your using a tube header (anything buy a cast manifold) which has a thin material thickness, you will hear much more noise than you would with a cast manifold. Its not actually valvetrain noise, its hearing the valve operation from the header side.
I'm not second guessing you, but are you SURE this is a new noise? 100miles isn't a ton of time to get familiar with all the noises/strains/whistles the engine and truck will make at various speeds and rpm. A hot motor will sound different than a cold one, and if there was any fresh build work, the breakin period will change the sound as well.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-07-2016, 10:39 PM   #4
Sean1985
Sean1985's Avatar
Just a little update. Took it to gm since the motor is brand new and so far they found a loose rocker arm and broken valve spring. They're still digging into it. Pretty crazy. I followed th break in procedure perfectly. So far the dealer has been super honest.
Old 09-08-2016, 07:23 AM   #5
zach_carver
zach_carver's Avatar
Wow wouldnt of expected that.. Atleast they are figuring it out!
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 09-08-2016, 12:34 PM   #6
66ChevyMax
66ChevyMax's Avatar
Glad you took it in and progress is being made
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 09-08-2016, 04:02 PM   #7
solidaxel
solidaxel's Avatar
Were you using the GM warranty that came with the LS from GM?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-08-2016, 05:29 PM   #8
Sean1985
Sean1985's Avatar
Yes it's under warranty from gm. Also just got word they replaced valve spring and rocker arm. Same thing. Replacing lifters which is what I thought was the problem. I've heard some lifter issues with the ls3.
Old 09-08-2016, 10:54 PM   #9
solidaxel
solidaxel's Avatar
I guess I better fill out my warranty card and send it in!
Just paid for a LS-3 (19301326) but do not have it installed.
How long did you have the engine before you started it?
Is there a time period on these new crate engines, and does it start with delivery date?
LS 3 4L70E
Old 09-08-2016, 10:59 PM   #10
Sean1985
Sean1985's Avatar
I had for about a 6 weeks before I started it. I didn't get a warranty card. Just took my receipt with me. I ordered it from jegs. As soon as I got the motor I did a Holley oil pan and then primed the motor while it was on a stand. Then I primed it again before start up.
Old 09-08-2016, 11:07 PM   #11
solidaxel
solidaxel's Avatar
That it !
Your Chevy dealer sounds like a great outfit!!
LS 3 4L70E
Old 09-21-2016, 11:16 PM   #12
Sean1985
Sean1985's Avatar
Bad lifter and this was my push rod. Took 2 weeks but everyone was super cool and did a great job
Old 09-21-2016, 11:59 PM   #13
72MARIO
72MARIO's Avatar
How do you prime a ls engine ? Glad the dealer took care of the problem nice to see a warranty actually mean somthing
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-22-2016, 09:43 AM   #14
Sean1985
Sean1985's Avatar
I primed it with a oil primer tank. You put the oil in the tank and fill it with compressed air. I took out the oil pressure sensor and bought a fitting for it. Then I took my Holley oil pan and drilled and tapped the block off port to accept a 1/8" pipe tap. Then put a gauge in it. I did a mechanical guage when it was in the garage then I hooked up my Dakota digital guage when it was in the truck.
Old 09-22-2016, 09:49 AM   #15
66ChevyMax
66ChevyMax's Avatar
You can also turn the motor over without the ECU being hooked up. I did this with my gauges hooked up, took about 5 hits with the starter before I had oil pressure.
Craig
Old 09-22-2016, 09:50 AM   #16
66ChevyMax
66ChevyMax's Avatar
That is one sad looking push rod, glad you got her fixed up.
Craig
