Old 09-15-2016, 11:31 AM   #1
newbober
72 Rear Disk
Anyone who has used a rear disk conversion kit. I'm looking at various manufactures. They seem to range from $275.00 to over $800.00. I guess the right stuff one is cheapest, but doesn't even have a provision for E brake. It's probably Chinese junk for parts. Doe's anyone have any experience in this area?
Thanks, Bob
newbober is offline   Reply With Quote
Old 09-15-2016, 01:14 PM   #2
Cape Codder
Cape Codder's Avatar
Re: 72 Rear Disk
My experience with rear discs is only with oem setups. The draw back is the parking brakes. even the factory setups leave a lot to be desired. More trouble than it is worth in my opinion. Your front brakes do 70 % of braking anyway so unless you are road racing drum brakes will stop just fine. I may feel this way due to living in New England where the park brake stuff just rusts and siezes . My 98 truck is one of the last rear drum trucks they made and I have no desire to swap to discs.
Cape Codder is offline   Reply With Quote
Old 09-15-2016, 02:54 PM   #3
truckdude239
truckdude239's Avatar
Re: 72 Rear Disk
going to move this to the 67-72 forum for you should have better flow there
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-15-2016, 02:54 PM   #4
Willie Makeit
Willie Makeit's Avatar
Re: 72 Rear Disk
I had rear discs on my '67 and can honestly say there was no detectable difference in the braking performance over the drums.
Willie Makeit is offline   Reply With Quote
Old 09-16-2016, 01:32 AM   #5
crakarjax
crakarjax's Avatar
Re: 72 Rear Disk
Thats because you didn't *need* more brakes. Discs dissipate and stand up to heat better, and have a higher potential stopping force.
Check out cap'n fabs camaro brackets, uses 97 camaro calipers and impala rotors.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 09-16-2016, 07:30 AM   #6
Cape Codder
Re: 72 Rear Disk
Where is the park brake? It is required in my state for safety inspection.
Never mind on second look I see it hanging below without the cable.
Old 09-16-2016, 12:07 PM   #7
ls1nova71
ls1nova71's Avatar
Re: 72 Rear Disk
I have this exact same set up on my blazer, captainfab brackets, Camaro calipers and Impala SS rotors, and they work great! I even used the Camaro park brake cables, just had to move the forward mount on the trailing arms back a little and got an intermediate cable that was the right length. Way better than spending $800 imo.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-16-2016, 01:58 PM   #8
Willie Makeit
Re: 72 Rear Disk
that's my entire point. there is virtually zero performance gain with rear disc brakes on one of these body style trucks. the weight bias front to rear negates any performance gains that rear discs might offer.
larger front brakes is a different topic all together.
