Old 10-05-2016, 01:20 PM   #1
D.PASSMORE
One of the First
D.PASSMORE's Avatar
1969-72 Power Steering Pump replacement
I've done some research, mainly on the board and it seems their is a issue with getting the correct replacement Power Steering Pump.
I ordered the recommended AC/DELCO part number ACD# 36P1410 / GM #19319936 (all pictures show round type). The one I received was the square reservoir type, not the round long neck type that was pictured. The square type will not fit in the OE 72 truck brackets. So, I'm headed to NAPA to see if I can match one up.
Or, has any body figured out the correct part number for the exact replacement?
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
Old 10-05-2016, 03:03 PM   #2
flaa1a
flaa1a's Avatar
Re: 1969-72 Power Steering Pump replacement
I think we ended up using parts off the new one to rebuild the old one for the same not fitment reason...
flaa1a is offline   Reply With Quote
Old 10-06-2016, 09:25 AM   #3
joeydurango
joeydurango's Avatar
Just posted about this in another thread - NAPA sold me the square type as a direct replacement for the "chimney" style round one. As you found out, it doesn't work. I was able to use my old pump after all. If yours is bad/leaking, you may need to rebuild it... I haven't found a source for the old style pumps except used on eBay, and then you just don't know what you're getting.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER
1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD
1976 Trans Am | 400/4-spd | SOLD
1976 Trans Am | 455/4-spd | TOTALED
joeydurango is offline   Reply With Quote
Old 10-06-2016, 10:01 AM   #4
D.PASSMORE
One of the First
D.PASSMORE's Avatar
I don't have a "chimney" style, I just have the brackets and accessories. I think I found a used one that a friend is going to sale me. I'm wondering if the reservoirs can be swapped out with square pump. I did find a replacement though, pricey...
http://www.tuffstuffperformance.com/...ack-6198b.html
I haven't had time to really exam all the details of this item
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
Old 10-06-2016, 12:11 PM   #5
ajviper
ajviper's Avatar
You can source the chimney style from Classic Industries or any of the car reproduction part suppliers. Cars used them from 1969 and back. 1970 cars went to the rectangular.
I think even Advance Auto Parts carries the old style pump.
Chevy Runs Deep.
1956 210 LS1 TH350 3.31 Posi 12 Bolt
1969 Z/28 5.3 T56 3.73 Posi 12 Bolt
1973 Nova SS 355 TH350 2.73 Posi 12 Bolt
2000 K2500 Suburban LS 6.0 4L80 3.73 G80
2005 K2500HD CCSB LS 6.0 4L80 4.10 G80
2010 2SS/RS Camaro LS3 T56 Aqua Blue Metallic
ajviper is offline   Reply With Quote
Old 10-06-2016, 02:10 PM   #6
LongBox
Been following this thread with interest, as I'd like to convert my 69 350 V8 truck to PS. Found this at Classic Industries. http://www.classicindustries.com/pro...ts/ps6084.html
Does anybody know if it is correct for 69 V8s. No AC on my truck if that makes a difference.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 10-06-2016, 09:52 PM   #7
jerry moss
Born Psycho
jerry moss's Avatar
Smile Re: 1969-72 Power Steering Pump replacement
Dave,
great talking to you this morning. i checked the 71 K20 pump we spoke about and the can looks good. i'll try to shoot you a call in the morning since it's 7 o'clock p.m. out here.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 10-06-2016, 10:16 PM   #8
joeydurango
Glad to know there are new sources out there... for when my 44-year-old pump finally goes!
Old 10-09-2016, 02:07 PM   #9
zosoppp
Rock auto has listing with pictures of both types/multiple vendors. Might be worth a look.
zosoppp is offline   Reply With Quote
Old 10-09-2016, 02:11 PM   #10
davepl
davepl's Avatar
Is it not the case that the pump itself is actually the circular section and it can be moved from one reservoir housing to another? I seem to have a vague member of doing this years ago on my Camaro in order to retain the chimney style when all I could find is the square... but it's a hazy memory of 15 years ago!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 02-05-2019, 01:19 PM   #11
Chris 71 K10
Chris 71 K10's Avatar
Ordered one of these this morning I will update with fitment but the pic and description on their site matches up and lists 1971 K10. Thanks always to the board for the great resources and info!
Chris 71 K10 is offline   Reply With Quote
Old 02-05-2019, 01:50 PM   #12
webfoot
Exactly, if you get the rebuilt pump only it comes with a new O-ring seal to fit into your old reservoir. Its not too hard to remove the pump.
The 2 (?) studs and the pressure relief valve are the only thing holding the pump to the body.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 02-05-2019, 03:37 PM   #13
El Dorado Jim
sub'd
El Dorado Jim is offline   Reply With Quote
Old 02-06-2019, 09:33 AM   #14
Eagle9502
My original pump on my '71 K20 was leaking from the O-ring at the pump. The original reservoir was pretty beat up from the previous owner. I ordered a pump with reservoir from O'Reillys and when it came in it was the square style that will not work. I ended up taking it back and ordering just the pump without reservoir. I put the new pump in my old reservoir and fought trying to get the o-ring to seal. Luckily I had another original one laying around that I ended up using. I must've had the pump on and off 10 times.
Eagle9502 is offline   Reply With Quote
Old 02-06-2019, 10:51 AM   #15
Tallguy
Mine worked but it leaked. Was able to get a "seal kit" with all the 'O' rings and stuff from Auto Zone. I think it was about $12 in 2018.
Tallguy is offline   Reply With Quote
Old 02-06-2019, 11:53 AM   #16
rpmerf
rpmerf's Avatar
Rock Auto lists them with and without reservoirs.
https://www.rockauto.com/en/catalog/...ring+pump,7380
This one with the reservoirs looks correct, AC Delco also.
https://www.rockauto.com/en/moreinfo...031690&jsn=453
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
