Old 11-06-2016, 10:11 AM   #1
7tee
7tee's Avatar
Frame off help needed...
A friend with a 68 step side finally got his powder coated frame back after 9 months (wow)and most of the chassis bolts are not to be found.
For a start:
1) What size bolts are for the engine cross member and torque
2) Where to find the 4 upper control arm shaft bolts
This friend knows "nothing" and for me, just a pic and information and I believe I can help him. You guys have helped me before and I hope you will bare with me on this one. Thanks Ed...
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 11-06-2016, 11:16 AM   #2
RodnRudy
RodnRudy's Avatar
Re: Frame off help needed...
If by engine cross member you mean the main cross member that goes under the engine, it takes 7/16-14 by 1" grade 8 bolts lock washers and nuts. Check the LMC catalog for the cross shaft studs. Purchase a 67/72 Truck Assembly Manual. It will be invalulable in your friends re assembly process. Torque for the bolts can be found in the manual but I think it is 55-65 ft lbs.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 12-25-2016, 01:02 PM   #3
7tee
7tee's Avatar
Does anybody have any input to what these spindles came off of and what year...
39RHGM 264 6274264 F288
34LHGM 263 6274263 F289
Going to be doing a front drum to disk conversion on a '68 and not sure if they will work and what size inner and outer bearings to use.
The caliper#'s with spindles read:
2L K18007152GM
7R 5474177
Thanks Ed
2010 Acura RL...
Old 12-26-2016, 02:46 PM   #4
7tee
7tee's Avatar
2L K18007152GM
7R 5474177
Thanks Ed
At this point it seems that the spindles fit 73-87, does this list seem right and complete or am I missing something?
1. 73-87 upper and lower ball joints
2. 73-87 outer tie rod
3. 68 outer tie rod (to use as inner)
4. Use Classic performance CP4SC_SAR reducing tie rod sleeves (11/16" to 5/8")
5. Use existing 68 drag link
2010 Acura RL...
Old 12-28-2016, 07:24 AM   #5
7tee
7tee's Avatar
ttt
2010 Acura RL...
