Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-24-2016, 07:40 PM   #1
AngryPirate
AngryPirate's Avatar
WTB - 1960 GMC rating plate
Mine is missing.
It's this one, but the one for the 1960 will be slightly different (engine type)...
Thanks!
-Scott
AngryPirate is offline   Reply With Quote
Old 11-25-2016, 01:58 AM   #2
1960chevypanel
Re: WTB - 1960 GMC rating plate
I'll check if I have one. I know some of the 1960 GMC's had the VIN number on that plate.. Is yours a 1/2 ton truck or ?
1960chevypanel is offline   Reply With Quote
Old 11-25-2016, 02:31 AM   #3
AngryPirate
It is a 1/2 ton truck, SWB. My vin/serial is on the A pillar.
Thanks for checking 1960cp!
Old 11-25-2016, 11:38 AM   #4
GMCNUT
GMCNUT's Avatar
if your VIN is not stamped in the rating plate, your truck is a 61 up instead of a 60 regardless of what the title says. Many trucks were titled in the year sold rather than the year model they actually were - I have never seen a true 1960 GMC that did not have a single tag for VIN and rating.
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 11-27-2016, 05:34 PM   #5
1960chevypanel
hey steve what would be the most "correct" rating plate in this case then? so i know what to look for
Old 11-28-2016, 01:03 AM   #6
GMCNUT
GMCNUT's Avatar
Lets see if the 6066 crowd agrees or argues with me on my assertion that 1960 was the last year of the VIN being on the kick panel tag - not sure if those guys have weighed in yet. If they agree, then the kick panel type all-in-one tag is what your 1960 needs.
Old 11-28-2016, 01:24 AM   #7
1960chevypanel
well in this case if his vin is on the door jamb he won't want a kick panel tag with a vin on it.. do you know the gvw for a shortbed off the top of your head?
Old 11-28-2016, 02:15 AM   #8
AngryPirate
My serial # plate says Max. GVW 5200 and my serial # ends in an 'A' which I believe means 6000 lbs or less.
I have a 305A engine in my truck as well, which I believe is the 305 v6 that was in all 1960 GMC 1000 series.
I believe it will look something like this, but with 305A and slightly different HP ratings on it.
This rating plate may not exist without a serial # on it though. I really don't know.
I appreciate you looking though. ;-)
Old 11-28-2016, 02:17 AM   #9
AngryPirate
Oh man....don't start over there. I started a thread over there and a special fellow chimed in, not realizing things could have been variable as far as locations of ID plates.
He basically told me that my truck was 'fishy' and could be a clone and that I was trying to pull a fast one on the sheriff's office while trying to get a bonded title. Ugh.
Thankfully other, more seasoned members set him straight.
Oh, I see you're already posting over there too.
Nevermind...you know what's going on over there too ;-)
Last edited by AngryPirate; 11-28-2016 at 02:21 AM. Reason: realized gmcnut was already informed.
Old 11-29-2016, 01:41 AM   #10
1960chevypanel
I found a couple so far, but both are 305E. I'll keep looking.
Interesting though, I checked 4 different 60-61 trucks and they didn't have any kick panel tags - just the holes. So yours may not be missing - it might not have come with one, especially if all the data info is already on the pillar.
Old 11-29-2016, 12:37 PM   #11
GMCNUT
GMCNUT's Avatar
Hahahaha - you will never find a more testy group of so-called truck enthusiasts than in that 6066 GMC V6 group - they are all just waiting to get a new opportunity to start a pissing contest or prove someone else is wrong about an asserted fact they thought they knew. Most online forum moderators try to squash use of negative talk or criticism but not that one....sorry you have to tread lightly around that crowd. Your truck is A-OK with a door mounted tag, its just not a 1960. Its a N series 61
Old 11-29-2016, 12:40 PM   #12
GMCNUT
GMCNUT's Avatar
Pirate, I forgot - maybe you are the one saying your truck didn't have a tag at all - forgot that. So to be a 60 you need a kick panel 1960 tag w/ 1000 series VIN and if you are wanting a 61-62 identity tag, that is on the door frame and is a skinny tag that rivets to the two holes you found there
Old 11-29-2016, 01:26 PM   #13
AngryPirate
My truck does have a tag, it's just on the A-Pillar. I have noticed that there are kickpanel tags as well, that don't have the serial #, but it looks like my truck probably never had one since all of the rating information is on the A-pillar tag.
I was just trying to make my truck complete is all, but it seems it is...those holes in the kickpanel must have always been vacant.
Thanks for looking everyone!
Old 11-29-2016, 04:25 PM   #14
TJ's Chevy
TJ's Chevy's Avatar
I'm on that forum to "TJ's GMC." lol I've been bull headed over there, but our moderator there tends to punish the victims instead of the predators. One of the members there decided to start an argument with me so I defended myself. Next thing I know I get a nasty PM from that mod and the idiot that started the whole thing is going along freely. haha Oh well. Doesn't bother me. Glad I'm on this forum where the mods are fair people who work hard to make this place great for Everyone and not just a select few.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-29-2016, 06:08 PM   #15
60-66
60-66's Avatar
Steve , out of four 1960-1961 trucks I have , two 60s two 61s , three have the kick panel vin and one has the A pillar VIN. I have three 1962s , all have the A pillar VIN like the one 1961 does. NONE of the A pillar 1961 1962 VIN trucks have kick panel GVW tags . 1963 GMC has the normal GVW tag on the kick panel and then they changed the VIN tag to a spot welded stainless tag like Chevys. Theres nothing wrong with your truck Angrypirot , but there is a real lack of understanding over at the GMC site ! WOW!
I have a similar GMC VIN screw up. Its a 1966 GMC 4x4 panel with very low miles. Heres the problem, the VIN tag style is the same as a 1964-1965 tag, the vin tag style changed in 1966 . Everything on this truck is dated for a 1964 production model year. The tag was never removed , but like Steve is saying , GMC titled the truck the year the truck was sold. This truck of mine has 6000 original miles and was built for Civil Defense , that is most likely why it was titled so late as a 66. The "geniuses" over at the GMC sites first response is the tag and title are not to the truck ! What ? I buy it from the original owner township that bought it NEW in 1966 and the VIN got changed ? Theres a couple of egotistical idiot know it all's over there that are afraid to LEARN anything new and you cant tell them theyre wrong when they are . I used to go there quite often , not anymore. THE OLD 6066GMC site has some great info posted though.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-29-2016, 07:47 PM   #16
AngryPirate
Thanks for the information about your experiences with ID tags and ratings plates.
That information site attached to the 6066GMC site is pretty great, but one of the "know it all's" over there didn't want to admit he was wrong, so he said the information site was incorrect and he was right. UNREAL.
Oh well....it appears my 60 GMC may actually be a 61. At least some good information was arrived at on both sites forums around the ID plates.
Old 11-29-2016, 09:42 PM   #17
60-66
60-66's Avatar
I read through that post on the other site front to back. My question is , what made you think its a 1960 vs a 1961 ? When researching my 1966, that's actually a 1964 build , I checked all the dates on the engine , intake , heads block etc , were all dated for a 1964 production truck. Im using the dates like anyone would restoring a car. It might help you figure it out ?
Old 11-29-2016, 10:00 PM   #18
AngryPirate
Well, the guy I bought it from told me it was a 1960, but the date code ('N') on the serial # says it could be either 60 or 61. It could still be either but it seems like some are leaning more towards it being a 61.
Old 11-30-2016, 12:54 AM   #19
MusicMan70
MusicMan70's Avatar
My 61's data plate location. I'll have to look at my date stamped parts to see what I may really have .
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
