Old 12-16-2016, 08:03 PM   #1
Guyz55
i am sure someone has done this
Folks
I want to replace the chassis of my series 2 55 chevy 3100. Has anyone done/accomplished this feat ...if so , how difficult was it to remove the cab .are there ant tricks,secrets etc I should know about ... I already removed the front clip ....any input would be greatly appreciated
thank you
Guyz55 is offline   Reply With Quote
Old 12-17-2016, 12:45 PM   #2
1958Warrior
1958Warrior's Avatar
Re: i am sure someone has done this
I'm SURE this has been asked many times before.......and many answers
Up in the right corner on the forum page there is a box that says "Search this forum" it works for the sub forum Projects and Builds also , give it a try works great, Maybe type in "frame swap" for starters.
Give a man a fish and you feed him for a day. Teach a man to fish and you feed him for a lifetime.
Your Welcome.
1958Warrior is offline   Reply With Quote
Old 12-17-2016, 02:30 PM   #3
my56chevytruck
my56chevytruck's Avatar
Originally Posted by Guyz55 View Post
Folks
thank you
I can't help on replacing the chassis, but i've removed the cab, bed, etc. I have a lift that i've used to remove the cab and bed with. here's a few pics. Hope this helps.
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-17-2016, 02:45 PM   #4
Guyz55
do u remember how many bolts held the cab to the frame ...any idea how heavy the cab is ? could a few guys lift it...I wish I had a lift in my garage ...that would be awesome ...at least I have a garage
Old 12-17-2016, 03:14 PM   #5
lt155ruck
lt155ruck's Avatar
there are just 4 bolts holding the cab... as for lifting the cab off 4 could have done it.... but I wanted 6 with fresh paint
lt155ruck is offline   Reply With Quote
Old 12-17-2016, 04:37 PM   #6
OrrieG
OrrieG's Avatar
After wiring is unplugged disconnected, steering column and box removed, heater lines, transmission shift lever, etc. Easier if doors are off, if your door gaps and hinges are good use a 1/8" drill bit thru hinges to use a pilot holes when reassembling. Like someone said search function is your friend, this has been discussed a lot before. MIght want to look at the various build thread to see how different chassis swaps affect the work you need to do and out come. Might be better to keep the existing frame and upgrade suspension. That has been discussed a lot too, search will pick up those threads.
OrrieG is offline   Reply With Quote
Old 12-17-2016, 04:52 PM   #7
Dave0
I took the suspension off, put the frame on cheap rollers, cab on jack stands and rolled it right out!
Dave0 is offline   Reply With Quote
Old 12-18-2016, 12:18 AM   #8
R&B51
Couple places on this site I found some guys' good ideas worked for me. Built a cheap 2x4 cab dolly using some leftover castors that the feet on my HF engine hoist would slip under. For cab lift, simple 2x4 rectangle with dogs on ends to avoid slide and cross brace in middle with holes drilled across it. Goes across between door holes and out sides a little up against inside top of cab. Mounted trailer hitch insert in end of hoist upside down with ball pointing up and tried in the strip of holes in center brace of frame until balanced. Lifts cab like a charm and moved over onto cab dolly, dropped and presto. Made cab dolly longer in front so can tilt up on the "angle" under front of my 51 AD with strut placed when tilted can work on bottom of cab too.
Have pics but don't know how to load so you can PM me if interested.
Guys on this site rock, give me ideas every time I get on
Good luck
R&B51 is offline   Reply With Quote
Old 12-18-2016, 03:35 AM   #9
Softpatch
Softpatch's Avatar
many guys use a 2X6 beem inside (just the cab) fit between the door openings and a engine hoist reaching in pushing up the beams the cab it self ways maybe 350lb
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 12-18-2016, 12:04 PM   #10
63 & 64 Bowties
and a few others
One easy way
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 12-18-2016, 05:02 PM   #11
Russell Ashley
Russell Ashley's Avatar
I used straps like that to lift my bed when I removed it. Works great.
Russell Ashley is offline   Reply With Quote
