Old 12-20-2016, 03:02 AM   #1
mygirlz55
Lower fender bolts
Hey people, I'm looking for the bolt size for the lower rear fender bolt on the front fender of a 1955.2 chevy. Need to bolt fenders down.....the previous owner had wire to hold them in place.
I don't want to carry the whole fender into the hardware store to match up the nut to a bolt, and can't find it online anywhere.
mygirlz55 is offline   Reply With Quote
Old 12-20-2016, 04:12 AM   #2
mygirlz55
Re: Lower fender book
Oops...just realized the posting is titled ...'book'....it should be "BOLT"
Old 12-20-2016, 02:01 PM   #3
Iceman_70
Iceman_70's Avatar
on my '56 it's a 3/8-16 UNC bolt.
'56 Chevy stepside shortbed
SBC350 - TH350
12-bolt rear
Iceman_70 is offline   Reply With Quote
Old 12-20-2016, 02:30 PM   #4
mygirlz55
Thnx iceman.....I'll give that a try
Old 12-20-2016, 11:50 PM   #5
dsraven
bolts are pretty cheap. maybe buy a few fine thread as well. my truck seems to have a mix of fine and course depending on what is still stock compared to what has been jury rigged by the farmer. you can always take back what you didn't use, right?
dsraven is online now   Reply With Quote
Old 12-21-2016, 02:23 AM   #6
mr48chev
mr48chev's Avatar
You probably have one in the bolt bucket that you can trial fit to make sure what diameter and thread it is but I'd think 3/8 SAE or USS (Course/fine) would be the right one.
My ongoing truck projects:
mr48chev is online now   Reply With Quote
Old 12-21-2016, 01:34 PM   #7
greg_h
Mine is a 54 but better get the "giant" "fender washers" as well to keep from pulling through the slotted holes. As I recall on mine, there was the clutch head style bolts with no washers going from inside the bed, the fender washers, lock washers, and nuts.
greg_h is offline   Reply With Quote
Old 12-21-2016, 11:47 PM   #8
nvrdone
do you have a tap & die set ? I find running a tap in is an easy way to find the correct bolt & it also cleans up the threads
nvrdone is offline   Reply With Quote
