Old 12-28-2016, 07:29 PM   #1
bigsky
bigsky's Avatar
POR-15 On Aluminium ??
After reading the praises of POr-15 here, used it on rusted floor boards on 72 K10. One of my friends started using it on all of his old farm equip. and swears by it. Today he called and asked if POR-15 could be used on an old set of aluminum wheels, instead of powder coat? I do not know this answer, hoping someone here can help out. Thanks
bigsky is offline   Reply With Quote
Old 12-28-2016, 07:39 PM   #2
cdowns
cdowns's Avatar
Re: POR-15 On Aluminium ??
I think it is a bad choice
Old 12-28-2016, 07:44 PM   #3
GR8-68
GR8-68's Avatar
As long as you properly prep the surface I don't see why it would be a bad idea. It holds up well but will fade in the sun without a uv inhibitor
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
Old 12-29-2016, 07:20 PM   #4
suprachrgd82
Farmtruck desciple
suprachrgd82's Avatar
If I am not mistaken, Por-15 is a rust inhibitor, with the active ingredient of phosphoric acid. It would be a bad idea to put any type of acid on aluminum, as it will react and cause serious pitting.
For oxidized aluminum, a good polish (sanding for really heavy oxidation) would be ideal. It can be followed with paint, fresh anodizing, powder coat, or heavy coat of carnauba wax to prevent further damage.
suprachrgd82 is offline   Reply With Quote
Old 12-29-2016, 07:42 PM   #5
GR8-68
GR8-68's Avatar
POR-15® Metal Prep provides the best adhesion for POR-15® Rust Preventive Coating on any metal surface, including aluminum and shiny polished metal surfaces. Our simple process gently etches metal, creating an ideal anchor pattern for coatings such as POR-15® Rust Preventive Coating, while simultaneously leaving a zinc phosphate coating to insure chemical bonding of paint and steel. Avoid other preps that may leave harmful residues which prevent proper adhesion. After thoroughly degreasing your work piece, apply environmentally safe POR-15 Metal Prep to both neutralize any rust and etch any clean bare metal. This will allow better adhesion of POR-15® Rust Preventive Coating or any other coating. POR-15® Metal Prep is not caustic, corrosive, toxic or flammable.
Larry
"Project 68"
paypal.me/ldgrant
Old 12-29-2016, 07:46 PM   #6
GR8-68
GR8-68's Avatar
APPLICATION OF POR-15® TO NEW METAL
For proper adhesion to aluminum, galvanized metal, and smooth steel surfaces, prep with POR-15® METAL-READYT Rust Remover/PrePrimer. Keep surface wet for 15 minutes, then rinse off with water and dry thoroughly. This process will leave a zinc phosphate coating on the metal and insure perfect adhesion.
Larry
"Project 68"
paypal.me/ldgrant
Old 12-29-2016, 08:53 PM   #7
67 chevelle
67 chevelle's Avatar
paint over top of it , it does not like the sun
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
